A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
those who have used Mercon SP
Old 04-30-2014, 04:03 PM
raaizin's Avatar
Default those who have used Mercon SP
Anyone who has changed trans fluid and used Mercon SP, could you let us know how many miles since fluid change and any issues after.
Old 04-30-2014, 05:45 PM
dzywicki's Avatar
I have not used Mercon SP, but I have used Amsoil (fuel efficient synthetic) in two A6's with no problems.
Old 04-30-2014, 05:52 PM
uberwgn's Avatar
Raizin, you can get the correct fluid from Blauparts without having to spend too much. It's made by Ravenol and carries the VAG certification.
Old 05-01-2014, 12:43 PM
ProtoFly's Avatar
40k miles on Mercon SP, no problems.
Old 05-01-2014, 05:53 PM
raaizin's Avatar
lifeguard 6 is the fluid correct, what is the oe part number. Is it
G 055 025 A2
Old 05-01-2014, 07:12 PM
KnappAttack's Avatar
40,000 miles on Mercon SP in my 05 4.2 with no problems. No change in performance.
First 500 miles or so after the fresh fluid change had more positive and crisper shifts, then went back to normal after that. I did two changes with Mercon 5000 miles apart as I did not do a filter change the first time. I have 185,000 miles on the clock now. First change at 145,000, second change with filter at 150,000.
Old 05-02-2014, 11:49 AM
raaizin's Avatar
Thanks for the info Protofly & Knapp attack. If I get 185k out of my car I will be happy
Old 05-02-2014, 12:00 PM
Prospeeder's Avatar
The redline D6 fluid should also be compatible with the lifegaurd 6 fluid if your looking for another alternative.
Netopr
Q7 MK 1 Discussion
33
11-08-2019 02:55 AM
MontenegroATL
15
11-21-2005 11:32 AM
Quick Reply: those who have used Mercon SP
