A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Leaking washer fluid reservoir
Old 01-19-2015, 04:27 PM
am_ver's Avatar
Default Leaking washer fluid reservoir
Looks like I have a leak in the washer fluid tank - I'd filled up the fluid and saw a puddle next to the driver side door. And now there is no more fluid. From the top it doesn't look like you can see any leaks - but the problem is you can't see much from the top.
Anyone face this issue? What is the way to troubleshoot/fix?
Old 01-20-2015, 02:33 AM
royclark's Avatar
If you remove screws 3 & 5 you can fold the inner wheel liner back to reveal the washer tank.
# Number Description Qty.
windscreen washer system
1 4F0955453R wash water reservoir; use if required:; 431 955 465 A; 444 955 647; 7M0 919 382; 8E0 955 465 A 1
- 431955465A seal; 20,2X9,5; PR-8X0 1
- 444955647 bungs; PR-8X0 1
- 7M0919382 o-ring; PR-9Q3 1
- 8E0955465A bungs; PR-9Q3 1
- 7M0919376 water level switch; PR-9Q2,9Q4 1
- 7M0919382 o-ring; PR-9Q2,9Q4 1
2 1K5955651 windscreen washer system pump; sedan 1
2 1K6955651 windscreen washer system pump; for vehicles with wipe-wash; system for rear window; AVANT 1
- 1J0973722 flat contact housing with; contact locking mechanism; 2 pin; black 1
3 443955465 seal; 12X6,5 1
4 447857991J intermediate layer; modify in workshop; 130X165 *
5 N 90570802 hex. nut with washer; M6 4
6 N 90999502 hex collared bolt; M6X25 1
7 1K0955455 end cap 1
8 4F0955452A fluid reservoir; upper 1
9 8Z0955485 strainer 1
10 4F0955479B grommet 1
11 4F0955465B seal; 12X7 1
12 4F0955953B connecting pipe 1
13 8N0955875 connecting part 1
14 1J0955665C elbow fitting 3
15 N 0209022 cable ties; 3,6X246 X
16 4F0955845 hose bracket 1
17 4E0955998 grommet 1
18 8J0955988G spray nozzle, heated; right 1
19 8J0955987G spray nozzle, heated; left
Old 01-20-2015, 10:19 AM
am_ver's Avatar
Thanks Royclark!! Will open the screws and see if I can spot the leak!
Old 02-12-2015, 03:48 PM
am_ver's Avatar
Looks like i might need part 13, 14 and 15 as potential source for the problem. Does anyone know the part numbers for these? or point me to where I can get these part numbers?
Old 02-13-2015, 06:00 AM
royclark's Avatar
Old 02-15-2015, 05:20 PM
am_ver's Avatar
Opened the car again and filled the tank again with fluid. Now it appears that the water is dripping from the bottom of part #2 of the attached diagram. Can you please share part 2 and 3 numbers? Thanks much!
Old 02-16-2015, 06:43 PM
milan_o's Avatar
1K5955651 is the pump(#1) and 443955465 (#2) is the seal. The part numbers are stealthily hidden in the list under the picture. I missed it until just now.
Old 02-17-2015, 05:11 AM
royclark's Avatar
This is the pump - 1K5955651 | eBay
This is the seal - 443955465 | eBay
Old 02-17-2015, 10:19 AM
am_ver's Avatar
Thanks bud!
Old 01-21-2018, 04:05 AM
Angler9749's Avatar
Car is a6 c6 2.0tdi le mans avant Dec 2009. (system as in diagram posted above)
I also have a leaking "washer bottle" but it only seems to leak about 1 litre of fluid at a time after filling up but does so even when the car is stood on the drive. I have deduced that wherever the leak is it is gravity fed and having removed the wheel arch shroud and found no leaks on the bottom tank or pumps etc I think it is the seal between the top and bottom parts of the system. If this was the case it would explain the leak being limited to about 1 litre (to just below where the pipe from top tank goes into bottom tank) and it occuring when on the drive. I cannot see any water under the car so have no idea where it is running to. My question is - can parts 10 (grommet) and 11 (seal) be replaced by just removing the top tank assembly (no 8) or is it needed to remove the bottom tank to fit/renew part 10 (grommet)? Also is any sealant to be used when fitting the grommet to the bottom tank? Any advice appreciated.
Quick Reply: Leaking washer fluid reservoir
