Left headlight fuse 32 blows
Has anyone had the problem with fuse 32 blowing?
I have the AFS bi-xenon lights.
When I turn on my headlights, fuse 32 (20A) on the inside drivers side fuse block blows within 1 second.
Thanks in advance.
Thanks in advance.
I didn't have my computer with me so couldn't do a VCDS scan. I inspected the headlight assembly and saw the clips that hold the cover on the back had broken off and the cover was slightly open. It is very wet and raining here today so I will try again tomorrow after I get a new cover on the back of the headlight.
Ballast on the bottom side of the lightbulb assembly was the culprit. Verified by switching the ballasts since I already had the bumper off and could trade it with the right side pretty easily.
Out of curiosity I opened the cover on the ballast and noticed a lot of moisture inside the case. I suspect that the broken cover on the back of the headlight assembly was allowing water into the assembly and the water was somehow making its way through the connection into the ballast.
I did notice some condensation in the headlight several months ago but search results make me think it was normal behavior. I suspect the cover was broken at that time but I do not know.
I will post the VCDS logs after I get the new ballast installed.
Here are the codes from the VCDS scan, all is well after replacing the ballast.
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
Shop #: WSC 02335 785 00200
VCID: 66C3540851D06E11F57-8033
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01111010
Fault Priority: 2
Fault Frequency: 8
Reset counter: 243
Mileage: 183292 km
Time Indication: 0
Date: 2015.01.20
Time: 07:04:00
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 7
Reset counter: 243
Mileage: 183324 km
Time Indication: 0
Date: 2015.01.20
Time: 09:19:00
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 23436 444 54374
VCID: 285F1A309B44B86107B-807D
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02629 - Sensor for Swivel Module Position; Left
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 40
Mileage: 183288 km
Time Indication: 0
Date: 2015.01.20
Time: 06:58:18
Coding: 0013123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 243
Mileage: 183292 km
Time Indication: 0
Date: 2015.01.20
Time: 07:04:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 243
Mileage: 183324 km
Time Indication: 0
Date: 2015.01.20
Time: 09:19:00
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 40
Mileage: 183288 km
Time Indication: 0
Date: 2015.01.20
Time: 06:58:18
manuva
Audi 100 / A6 (C4 Platform)
09-27-2006 10:08 AM
sbh tuned
04-05-2004 10:34 AM
02oettingerA4
01-08-2003 01:29 PM
