A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Left Parking Brake Motor malfunction
Old 06-14-2014, 05:30 PM
am_ver's Avatar
Default Left Parking Brake Motor malfunction
Got this error code after starting the car - didn't engage/disengage the parking brake; error just came up after starting the car. Any ideas on the fix? Motor needs to be replaced - Or control module? Should I just start with checking the connection to the motor on the driver side PB?
Saturday,14,June,2014,16:54:45:26365
VCDS Version: Release 805.1
Address 53: Parking Brake
Control Module Part Number: 4F0 910 801 D
Component and/or Version: EPB CEFC0090 H05 0090
Software Coding: 0005022
Work Shop Code: WSC 26131
1 Fault Found
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Freeze Frame
Fault Status: 11111011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 177
Mileage: 195368 km
Time Indication: 0
Date: 2014.06.13
Time: 17:51:27
Freeze Frame
Voltage: 11.28 V
Count: 116
Old 06-14-2014, 08:57 PM
raj99's Avatar
Start with troubleshooting connections. Then evaluate components
Old 06-15-2014, 01:20 PM
KnappAttack's Avatar
I unplugged mine, blew out and plugged back in using dielectric grease. Has worked fine since. That was a couple years ago.
JGiardino89
05-10-2020 04:43 PM
tjf
9
01-15-2019 07:45 AM
mikesd1980
03-22-2013 07:15 AM
wfroehlich
07-06-2012 12:29 PM
SCL
10
07-23-2008 09:08 AM
Quick Reply: Left Parking Brake Motor malfunction
