Lug Bolt Torque? - AudiWorld Forums
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Lug Bolt Torque?
Old 05-10-2010, 07:56 AM   #1
Default Lug Bolt Torque?
Just off the top of year head, anyone know the torque (ft/lbs) for our lug bolts?
r1racer is offline   Reply With Quote
Old 05-10-2010, 09:51 AM   #2
90 ft/lbs
05A632 is offline   Reply With Quote
Old 05-10-2010, 11:46 AM   #3
Quote:
Originally Posted by 05A632 View Post
90 ft/lbs
Thanks...i had a new tire put on a while back and the shop that put it on had to torque it to a billion ft/lbs...my local shop couldn't get the bolt off and I ended up stripping it.
Torch didn't work, extractor sockets didn't work so now I am attempting to drill it out. May lose the wheel or have to take the hub off...what a pain in the azz.
Old 05-10-2010, 09:52 PM   #4
Sorry to hear. The bolt may be cross threaded. Because Audi uses bolts instead of studs for the tires, it is quite difficult to hold the wheel against the hub while threading the first bolt in its hole. Some mechanics will blast the bolt home with the gun. Had it happened to me once. Cost me a wheel and a set of rotors.
lane22 is offline   Reply With Quote
Old 05-11-2010, 06:29 AM   #5
Quote:
I got it off last night (carbide tip masonry bits did the job). It wasn't cross threaded just torqued liked hell. Scratched up the wheel quite a bit so I'll be using that as the spare. Took about an hour.
Thread Thread Starter Forum Replies Last Post
A6 C6 3.2 engine removal for timing chains uble1234 A6 / S6 (C6 Platform) Discussion 3 04-17-2016 04:57 AM
Is this valves hitting after timing belt change Quick Cal 4.2 V8 Discussion 5 10-29-2015 10:25 PM
License Plate Bolt Length? schalliol A6 (C7 Platform) Discussion 13 10-03-2015 07:56 AM
only 317 torque in the rs5? markN1689 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 7 10-01-2015 09:07 PM
05 3.2 tranny issues fixmya6 A6 / S6 (C6 Platform) Discussion 4 10-01-2015 03:00 PM
Tags
1998, 2003, 2007, a3, a4, a6, audi, bolt, lug, lugnut, nut, r8, s6, torque, wheel
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
