Missing Rear CV Boot Clamps
Just replaced rear brake pads today. I found out that both side of the Rear axis were missing CV Boot Clamps. See the picture. Not sure how long they were missing or broken off.
Do I need to refill the CV joint grease into the CV joints before putting in a new clamps? If I open the CV boot to refill grease, I am fear of contaminated the CV joint with dirt which may cause the CV joint to fail.
Any advise.
Thanks
Any advise.
Thanks
If they've not been sealed...the CVs are already most likely contaminated. I'd consider changing the boots and grease, but if you don't see any real issue with the current boots. Clean the area, put in new grease, and then make sure to seal them up well.
Had the joys of replacing my L/H outer CV boot on the weekend.....What a mess, glad thats over but..
JetTech 2.7T
05-14-2007 06:41 AM
When replacing front CV boot does the axle shaft need to be popped out of the front transfer case...
SNogaro4
03-07-2006 04:18 PM
SNogaro4
12-05-2005 02:21 PM
odelay12v
06-24-2005 11:15 PM
