MMI 2G Software Update
#11
My 08 A6 S-line had the identical software version. Please let me know if the upgrade is successful. I will do mine after your confirmation. Thanks.
#12
Check this link out for some insight:
Burn a CD or DVD from an ISO file
#14
Burn at the slowest speed as possible. When you leave it on auto or the high speeds you running chance of errors. On music CD it may not be a problem but on programming files if the checksum is off the disk will be rejected as invalid.
#16
google the free software for imgburn. It is the best. If you still have issue, the iso file may be bad.
#17
I am talking hardware. Set the burner on the lowest speed. I.e. select 1x instead of leaving it at 24x burning speed. Also use quality CD-Rs from established manufacturers like Taiyo Yuden.
#18
Using ImgBurn and setting it to 2x instead of max worked for me. Thanks very much!
#19
just to be clear, please be aware that should you do the update incorrectly and have an issue during the update, there is the chance that you brick your MMI. you should THOROUGHLY read up on the update and also have a battery tender to ensure you have continuity of power during the update.
Cheers
