A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
MMI Dead, how do I check the bluetooth module?
Old 12-12-2010, 09:25 AM
mp-avant's Avatar
Default MMI Dead, how do I check the bluetooth module?
I read it's under the driver's side carpeting, how do I go about removing it to check?
Old 12-12-2010, 10:47 AM
pcamaj's Avatar
if the whole MMI is dead then the MMI module (INTERFACE)is down , unless u traced the problem. the mmi module is inside glow comp. u have to remove glow comp to replace it...
Old 12-12-2010, 11:45 AM
mp-avant's Avatar
Default so i get the mmi boot screen, then it just shuts down?
any idea about that?
Old 12-12-2010, 06:11 PM
pcamaj's Avatar
in the work order done by the dealer, it says "remove glow box and replaced
the # 4F0-910-732-QX"
but u must make sure its the module 07.. if u have vag-com u should be able to check...
Old 12-14-2010, 07:01 AM
mp-avant's Avatar
Broken down and took it to the dealer and the found that the washer fluid line to the rear windshield leaked into the compartment that holds the bose amp, nav, radio etc and fried it. luckily this is being covered by the CPO warranty. parts alone would have been $4k!
Old 12-14-2010, 06:16 PM
pcamaj's Avatar
Wow, good to hear you were covered....
my next car if it is an audi it will definitely be a CPO. or nothing... i was also thinking to switch to Benz...
Old 12-14-2010, 07:27 PM
triplecore's Avatar
do you have a station wagon? Or do all a6 have washer fluid running to the rear; I don't remember any spray nosels on the back of my car.
Old 12-15-2010, 06:10 AM
mp-avant's Avatar
yes it's a wagon so it has the rear wiper and sprayer
Old 12-15-2010, 04:58 PM
Dufferdude's Avatar
This happened to me, there's a TSB #2013209 out on it. The washer line where the hatch pivots at the top is made of a harder plastic tube. Mine was 6 months out of warranty. needless to say I was frickin mad. Should of been changed earlier no matter what.
http://www.fileden.com/files/2007/3/...b.92-06-01.pdf
Old 05-05-2015, 06:14 AM
Roneyroberts's Avatar
Default 4F0910732Qx
Where can I get help to find this part (4F0910732Qx) my mmi is also dead and the dealer is charging me almost 3k to fix it.
I need help finding a moderate price on the part
Wanta2009TT
01-12-2009 01:37 PM
sozdemir
04-18-2008 12:39 PM
silver A$
04-07-2005 05:25 AM
coocoomike
12-24-2003 11:28 AM
RickS
07-23-1999 03:40 PM
Quick Reply: MMI Dead, how do I check the bluetooth module?
