A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
MMI Knob Replacement
Old 02-20-2009, 09:36 AM
BrianE's Avatar
Default MMI **** Replacement
Looking at puchasing an 06 A6 with crappy ****. Is this easy to replace? Is it just a tug? Where is best place to get replacement and how much?
Thanks,
Old 02-20-2009, 10:04 AM
Member
08a6ing's Avatar
Default Re: MMI **** Replacement
Mine broke off in my pervious '05 ... dealer swapped out the whole unit. Took 4 days.. suffered the indignity of driving a base A4.
Broke again (my fault) - super glued it. Never an issue again.
Just depends on 'where' it's broken and how badly... sure you can tell the difference between dealer visit and home repair.
Old 02-20-2009, 11:51 AM
danno6's Avatar
the know in my 2005 was broken when I bought it last year. I purchased a new one from genuinevwaudiparts.com. I then took a pair of adjustable pump pliers and pulled the old one off (put some rags on teh console so I wouldn't scratch it). The new one pops back on with a little pressure. there is a snap-type ring that holds it in place. very easy to do, if it is just the ****.
Old 02-20-2009, 03:33 PM
Member
08a6ing's Avatar
yeah Danno6 is totally right about how to remove it.. if the spring is missing or part of the reason it's loose (assuming that's the problem) then you can line it up and use a dab of super glue...
It's really a pretty simple fix once you see what's involved.
Old 02-21-2009, 07:32 PM
Johnstay's Avatar
Default Use a two part clear epoxy
Like he says, cover the console so you don't drip.
It will work just fine and you won't need to worry about it going bad ever again.
If you search the archive you will find the same issue with a resolution described in much greater detail.
Old 11-24-2011, 03:07 PM
csmiller14's Avatar
Does anyone have a part number for the ****? because I am in need of one badly. in a drunken night it broke and the cover of the **** keeps coming off. kinda annoying when you drive an hour to work.
Old 11-24-2011, 05:53 PM
MainlandMig's Avatar
i would have guessed the **** didn't have its own part #...maybe it does... i bet the dealers try to get everyone to replace whole mmi unit.
my main button works just fine but is peeling a bit... my power on/power off/volume button is flaky... it sometimes doesn't power off when depressed down... i have learned to do a funky lean to one angle then press down and that works 80% of the time.. i pulled it straight up and off once and looked to see if i could finagle something but i couldn't.. i have minor sticky buttons issue when its cold ...maybe ill replace it if some thing major developes but for now ill live w it
Old 11-24-2011, 10:44 PM
A6Gary's Avatar
P/N is 4F0–919–069–A, lists for $75, can buy for $55.80 at Genuineaudiparts.com. or $56.25 at audipartsnationwide.som.
Old 11-25-2011, 04:43 AM
CLICK for helpful webpage
Old 06-21-2015, 11:42 AM
AudibleA5Quatro's Avatar
Not willing to pay the $75? I drilled a hole in a brass rod to fit the center stem. Tapered the bottom so there was plenty of movement. Works just fine. Will try it out for a week and if so I will place some loctight to fix it in place. Might consider changing to an aluminum rod.
Quick Reply: MMI Knob Replacement
