A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Navigation Pre-Wiring -- Question Though
Old 10-24-2014, 03:42 PM
  #11
Fastbird's Avatar
Will do. May or may not happen depending on if/when the car sells (though I'd like to add the NAV just as a selling bonus).
Though now I'm wondering if that plug is the correct one for the NAV or if it's for the Satellite radio.
Old 10-24-2014, 04:57 PM
  #12
roylok's Avatar
Although green, brown and blue connectors look the same, they are not. You will find out that trying to plug either the green or brown on the Navi drive wont work. The antenna Fakra connector for GPS has two grooves opposite each other on the inside, like this
Take a look at yours, the green has no grooves, and the brown has only one. GPS antenna is definitely blue.
Old 10-24-2014, 06:17 PM
  #13
roylok's Avatar
The power Connector and Optical will work for both Satellite and Navigation, they are interchangeable. I am sure of that I have tried it. If digging for the GPS connector proves to much for you, a $20 hideaway antenna with fakra connector will make the whole operation much easier.
Old 10-24-2014, 09:23 PM
  #14
Wake96c4's Avatar
Originally Posted by Fastbird
That would be killer if it was. If not, I can always use one of those hideaway ones based off the research I've seen. Or I'll just wire it in. It's not rocket science.
My 05 didn't have nav from the factory but I added it and used a cheap magnet GPS antenna and tucked it under the back deck from inside the trunk. Works great.
If you go that route look for an antenna with a fakra (spelling?) connector, that will plug right into the rear of the GPS DVD drive.
Since I had XM from the factory I had to get a Y-cable to add the GPS. Car recognized it right away when I started it up, no programming necessary.
One thing to keep in mind is that you might need to be careful of which DVD map disc you use. I believe version greater than 5.0 needs updated MMI software to work.
Old 10-26-2014, 05:47 PM
  #15
Fastbird's Avatar
Thanks to a very friendly member here, I just snagged a NAV DVD drive on the 'bay for $160 shipped. Can't beat that.
Old 10-27-2014, 03:25 PM
  #16
Fastbird's Avatar
So looking around, I see there's plenty of fakra Female to Female extension cables available. Does anyone have an approximate length needed to run from the NAV DVD player to the pillar connector where the connection is made?
eggsngrits
12-08-2021 06:58 PM
xkahn
02-08-2018 10:43 AM
cdu
Audi allroad
09-05-2015 08:11 PM
PTC32
09-03-2015 05:17 PM
o6A4Audi
09-01-2015 07:07 PM
Quick Reply: Navigation Pre-Wiring -- Question Though
