Cooling fan on all the time
Hi, the cooling fan runs all the time the engine is running, even from cold. the fans run at high speed.
So I thought it was the controller and changed it for a new one.
Sadly its the same, any one any ideas what else it could be.
A6 Avant 2010 2.0tdi
fans
Sounds like you should read this thread: https://www.audiworld.com/forums/a6-...nning-2880430/
Fans running all the time
Now fixed,
Thought I would post this as I had to take the car to an auto electrician in the end. They diagnosed faulty air-conditioning pressure sensor which is located behind the front bumper.
So after £300 and an air-conditioning recharge everything is working properly now.
This also fixed a fault which I thought was unrelated where the heater was blowing cold on the auto setting.
This works properly now and doesn't blow any until it is hot.
So all in all a tricky little thought to find and is completely unrelated to the fan control modulewhich I changed unnecessarily.
The moral of the story here is get the codes checked before you buy anything.
DesmoTesta
05-16-2006 05:47 PM
DesmoTesta
05-15-2006 07:08 PM
