need help with alarm siren..please help
i just got me a 2008 audi a6 s-line .when i lock or unlock the car it doesent make any noise...even when i press panic button. only the lights blink but no noise .
can any1 out there please help me and tell me what to do
First can you post the faults that are appearing, captured via the vag-com? Then try reseting all the codes and see if that addresses your issue.
Secondly, it may actually be an issue with the battery in the alarm module, but that should show up on the vag-com pull.
Thirdly, it may also be a fuse issue. Simply pull the fuse associated with the alarm on your car and see if it's good...if you don't know how to do that, just go to your local auto parts store and ask them to test it, then either get a replacement (if bad) or reseat it (if good).
good luck
ok great you have a vag-com.
good luck
good luck
2KS4
07-09-2008 08:01 AM
