A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Parking Brake - making screeching noise?
Old 03-06-2012, 12:12 PM
FUBAR 4.2's Avatar
Default Parking Brake - making screeching noise?
Hey guys,
When I put on my Parking Brake (life the button) I hear (what I can only explain as) rubbing rubber along a wet, painted garage floor...(like when you turn your steerting wheel while stopped) sort of a screeching sound - is this normal?
Thanks,
Old 03-06-2012, 08:37 PM
A6Gary's Avatar
You should hear the electric motor running to engage the brake pads to the rotor. So, if you're not getting any DTC warnings about EPB, then your parking brake is probably just fine.
Old 05-09-2014, 03:00 AM
padecastro's Avatar
Originally Posted by FUBAR 4.2
Hey guys,
Thanks,
Hey, I have an Audi A6 and I'm hearing the same noise you described. So I wonder if you found out if it is normal. If the noise is not normal, you have discovered the reason for the noise, and got discovered how to fix?
Thank you in advance for your attention.
Old 05-09-2014, 03:02 AM
Tech Guru
4Driver4's Avatar
Best solution is to stop using the parking brake.
Old 05-09-2014, 06:22 AM
padecastro's Avatar
Thanks for the suggestion, I will do that at the moment and will soon seek a mechanic to definitively resolve this.
Old 05-09-2014, 05:29 PM
mill3241's Avatar
Mine makes that noise everytime. I'm pretty sure its normal. Probably the electric motor.
motionpotion
Audi allroad
04-09-2022 04:55 AM
Jack27t
03-29-2006 10:41 AM
Oettinger_A4
11-17-2003 11:41 AM
Deutschdan
Audi 100 / A6 (C4 Platform)
11-20-2002 12:03 AM
a418tq
10-08-2002 05:12 AM
Quick Reply: Parking Brake - making screeching noise?
