A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Odd problem.....head gasket maybe???
Old 08-02-2015, 06:55 PM
voss69's Avatar
Default Odd problem.....head gasket maybe???
Just needed my A6 towed. It is odd...it was idling for about 1h in the parking lot. When I started to drive it it after 50 feet it started to smoke white out of both exhaust pipes. Then started shaking and stalled. The white smoke DONT have the sweet smell from coolant. The coolant level is at normal. It doesnt bubble in the reservoir when i start the car up again. There is no water in the oil and the oil level is normal. The engine did not overheat and there are no leaks. No error codes. Any further tries to star the car ended the same. starts fine...idles fine...then in seconds white smoke starts and starts running rough and then stalls.....any ideas??? i am lost.....
Old 08-03-2015, 04:10 AM
BillBoost37's Avatar
Which motor do you have?
Old 08-03-2015, 05:18 AM
voss69's Avatar
Its the 3.0...
Old 08-03-2015, 06:05 AM
2005 3.0?
Old 08-03-2015, 07:13 AM
voss69's Avatar
2005 3.0?
3.2
Old 08-12-2015, 02:36 PM
Former Vendor
CarPartsDiscount.com's Avatar
Could be related to your PCV valve. If that ends up being the problem here is a link to some replacement options
https://www.carpartsdiscount.com/cat...html?3594=2131
also enter code 4FVL7K to save 10% at checkout.
baileyevs
Q7 MK 1 Discussion
9
08-04-2019 01:07 AM
micklemdube@gmail.com
10-21-2018 11:48 PM
A Foore
05-16-2004 04:02 PM
nocondorfx
11
04-23-2004 09:32 AM
gixxer//s4
10-20-2003 05:40 PM
Quick Reply: Odd problem.....head gasket maybe???
