Oil pressure light only when turning right slowly
2006/7 A6 2.0TFSI
So the oil pressure warning sometimes, but literally only comes on when turning right at walking speed or turning right and coming to a stop. Turning right at speed or turning left at low or high speed doesnt do anything.
I changed the oil pressure switch to no effect.
Though the oil seems to be a bit thin, the guy i bought it from claims that its 5W-30, but it seems a bit to thin for that.
Any ideas what this could be? Is the thin oil related to the issue? Is it worth fixing or should i get rid of it?
I have quite the same problem, but probably a bit worse than your case. Have you got it fixed eventually?
Check my thread: https://www.audiworld.com/forums/a4-...8/low-2929323/
Are you sure a relay has gone or wire is loose? (Apologies for probably incorrect terminology).
Doesn't make sense that it would go one way, but not the other unless it was a sensor issue.
gdiilk
01-30-2016 09:07 AM
CustmS4
02-11-2003 06:54 AM
