P008A Code
P008A Code
Does any one know what this could be i can't find anything on it and before i go ahead and replace a high pressure fuel pump i want to try out the most financially feasible route. I do have warranty on the car on those parts.
This is whats covered.
Fuel delivery pump
Fuel injection pump
Fuel pressure regulator
Fuel sending unit
If you guys have any ideas what is causing this other than those listed things, I would be happy to hear about it.
Fuel delivery pump
Fuel injection pump
Fuel sending unit
This is what the mechanic told me he tested it and the pressure was at 4.0 for the low pressure fuel pump and he says i also need control module for the fuel pump. He determined all of this from the code using some snap-on tool he put on it. I don't trust this guy at all i don't have many options its the dealer or him.
Here is what i know so far he says it is the low pressure fuel pump along withe the module.
My question is where is this fuel pump? where is the high pressure fuel pump? Do i really need a module or this guy just trying his best to rip me off here!
This is the module
https://www.fcpeuro.com/products/aud...vag-4f0906093h
And i am not sure i am asking if this is the fuel pump?
https://www.fcpeuro.com/products/aud...vag-4f0919087f
Please guys help me out i can't find a good shop any where in Pittsburgh who aren't thieves. I am getting screwed i can't even get a straight answer from the shop they are pissing me off i been down there like 3 times and they aren't able little or no help they just want my $. If someone can tell me which fuel pump to replace where is it located would be a great help. Any help would be gladly appreciated i am a college student with student loans and bills i can't afford this every other month. AUDIs fun to drive but always bitch to repair something always going wrong!
This is the module
This is the module
This is the module
I couldn't possibly tell you whether you need the module or not. You need to have a VCDS scanner , if you can't afford one , see if you can find someone near you who can help. Otherwise you are just relying on people's guesses and throwing parts at the problem is going to get really expensive. If the fuel pump was tested and is not supplying enough pressure, I'd start with that (you replaced the fuse right?) Hold off on the module.
Good luck!
Edit: Fuel Pump 4F0919087F is the correct one.
Good luck!
Good luck!
Good luck!
PS. roy which fuse are you referring to that i should have replaced? I just changed the fuel filter following the 55k guide and i took out the fuse to depressurize the fuel system. Thanks again.
I got a VCDS scan found someone in the Pittsburgh area he also recommended me a good shop. So good they're backed up i gotta made an appointment This is the scan
also it had some old fault codes in the car i am assuming they were from cleaning the throttle body and the engine did knock a bit when it started after the cleaning but it idled smooth afterwards. Unless they are still there after i replace the LPFP located inside the fuel tank i am not going to worry about it.
the extra faults
This is the fuel pump in the trunk behind closer to the rear seats. Pretty sure it is but the shop would know better
adult image upload
Thank you guys i will report back with in a week or so once i get the car fixed... Let you know if it solved the problem.
adult image upload
Found an honest mechanic and he suggested it could be the sensor. And today i he changed it at 111600 miles and i have drive about 30 plus miles without any issue car responds better and the mileage has noticeably seems better.
This is the part he replaced
After replacing the fuel sensor and clearing the engine light at 111600 miles there is no light
I keep my fingers crossed and am very happy found a real Audi master mechanic in Pittsburgh.
The place i went is Pete's European Techniques. It's on stoops ferry rd by the airport if anyone ever needs a good honest mechanic in Pittsburgh!
Update carbon cleaning
Update... did carbon cleaning on the engine and ran a can a sea foam after words. Car starts a lot better and drives less restricted. Noticed that both valves are leaking driver side externally and passenger side internally in one spark plug chamber. Any good part place for these valve cover gaskets?.. Here are some pics from the cleaning Still no engine light!
[wrench][wrench][wrench]
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-25-2015 08:57 AM
ECS Tuning-Audi
09-25-2015 08:20 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
