Park Assist
Park Assist
Well looks like one of my rear parking sensors took a crap. It was working fine all day, then after work I got the solid tone after engaging reverse. Seems to be my left inner sensor is bad.
My question is, has anyone replaced one? Also if so, is it a PIA to do or simple since I've never taken off my rear bumper.
1. Bumper cover<O</O
2. Stud plate<O</O
3. Stud plate rivet<O</O
4. Stud plate grommet<O</O
5. Stud plate nut<O</O
6. Retainer plate<O</O
7. Retainer plate nut<O</O
8. Centre support<O</O
9. Lower panel<O</O
10. Lower panel bolt<O</O
11. Impact bar<O</O
12. Impact bar bolt<O</O
13. Impact bar nut<O</O
14. Energy absorber<O</O
15. Energy absorber bolt<O</O
16. Strap<O</O
17. Strap screw<O</O
18. Strap nut<O</O
19. Adjust bracket<O</O
20. Adjust bracket bolt<O</O
21. Adjust bracket nut<O</O
22. Adjust bracket screw<O</O
23. Adjust bracket fastener<O</O
24. Guide<O</O
25. Guide screw<O</O
26. Guide nut<O</O
27. Guide bolt<O</O
28. Guide-u-nut<O</O
29. Under tray<O</O
30. ?<O></O>
31. ?<O></O>
32. Reverse sensor<O</O
33. Wire harness
<O</O
<O</O
Remove rear bumper, unplug bad sensor, replace sensor, reconnect wire, replace bumper.
A little more info.
<TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Attachment points</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>1 - </TD><TD>Cover</TD></TR></TBODY></TABLE>
<TABLE class="cc einzug-explo abstand-explo "><TBODY><TR><TD class=einzug-liste>– </TD><TD>To remove, unscrew all nuts and bolts and detach cover towards rear.</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>2 - </TD><TD>Self-tapping screw</TD></TR></TBODY></TABLE>
<TABLE class="cc einzug-explo abstand-explo "><TBODY><TR><TD class=einzug-liste>q </TD><TD>1 Nm</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>3 - </TD><TD>Self-tapping screw</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>4 - </TD><TD>Cap nut</TD></TR></TBODY></TABLE>
<TABLE class="cc einzug-explo abstand-explo "><TBODY><TR><TD class=einzug-liste>q </TD><TD>4 Nm</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>5 - </TD><TD>Nut with washer</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>6 - </TD><TD>Guide</TD></TR></TBODY></TABLE>
<TABLE class="cc abstand-standard erlaeutrg-explo"><TBODY><TR><TD class=einzug-nummer>7 - </TD><TD>Grommet</TD></TR></TBODY></TABLE>
<TABLE class="cc einzug-explo abstand-explo "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Grommets must be pushed onto studs before installing cover.</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc bild-titel einzug-standard abstand-standard"><TBODY><TR><TD>Installing support piece</TD></TR></TBODY></TABLE>Note
<TABLE class="cc abstand-liste-erster einzug-standard hinweis-rumpf"><TBODY><TR><TD>The support piece only has to be installed if you are fitting a new bumper cover.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>To remove, press catch -arrow- to side and detach support piece downwards out of cover -1-.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Fit support piece -2- in cover as shown and make sure it engages.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Do not remove retaining tab until you have completed installation of cover.</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc bild-titel einzug-standard abstand-standard"><TBODY><TR><TD>Releasing support piece</TD></TR></TBODY></TABLE><TABLE class="cc achtung-rahmen abstand-standard einzug-standard"><TBODY><TR><TD class=achtung-inhalt>WARNING
<TABLE class="cc einzug-standard abstand-liste-erster achtung-rumpf"><TBODY><TR><TD>Never release support piece following removal, as this could cause injury.</TD></TR></TBODY></TABLE>
</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD>When re-installing the "old" bumper cover, the "old" support piece can remain installed.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>If bumper cover is replaced, new support piece must be clipped into bumper cover from underneath.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Once you have completed installation of the bumper cover, release support piece by pulling retaining tab -arrow-.</TD></TR></TBODY></TABLE>Note
<TABLE class="cc abstand-liste-erster einzug-standard hinweis-rumpf"><TBODY><TR><TD>Pulling the release tab releases the support piece, so that it then supports the bumper cover against the cross member.</TD></TR></TBODY></TABLE>
And some more
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc abstand-kap einzug-standard"><TBODY><TR><TD class=titel-kap>Removing and installing rear parking aid senders</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD>Fitting location: In bumper -arrows-</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
<TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Removing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Senders (inside) on vehicles with towing bracket:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove rear bumper cover</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Senders (inside) on vehicles without towing bracket:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Unscrew bolts -arrows-.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Reach behind the bumper cover.</TD></TR></TBODY></TABLE>
<TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>All models:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Unplug electrical connector -1- at sender.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Push both retainer tabs aside -arrows- and push out sender -2- inwards.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Installing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD>Installation is carried out in the reverse order; note the following:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Install rear bumper cover</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Tightening torque</TD></TR></TBODY></TABLE>
<TABLE class="abstand-tabelle layoutnormal frameall" border=1 cellSpacing=0 cellPadding=0 align=bleedleft><TBODY><TR class=th vAlign=top><TD class=cellborderrightbottom-th vAlign=top align=left>Component</TD><TD class=cellborderbottom-th vAlign=top align=middle>Nm</TD></TR><TR class=td vAlign=top><TD class=cellborderright vAlign=top align=left>Bumper cover to bracket</TD><TD class=cellborderright vAlign=top align=middle>1.5</TD></TR></TBODY></TABLE>
wiring new sensors
Hi, I need to know if the rear sensors are equal to the front sensors, because I have 4 rear sensors new and I need to use them on front bumper. Somebody knows how to wire this, because I have not the harness of the front bumper, but I have the rear harness . And it have 12 wires compared with the front harness that is only 6 wires. Thanks
SFexBOY
06-18-2007 10:52 PM
BIGDROCH
07-23-2003 02:29 PM
kweefe
10-13-2001 12:32 PM
