A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
A6 C6 steering wheel way too light on highway speed when turning left.
Old 08-19-2023, 05:27 AM
roobikxd's Avatar
Default A6 C6 steering wheel way too light on highway speed when turning left.
Hello.
So, as you can read from the title, that kind of problem occurred. I didnt have any play in tie rod ends (or in any suspension) but I thought I would change them because wheel was slightly off center and then when I bring it into shop they can easily align the wheels. (they needed a pretty good beating before I got the bolts out)
So, changed outer tie rods, went to alignment and now when driving you can feel that wheel turns to the left really really easily, you can feel it from 40-50km/h and on highway speeds its even worse, also it doesnt correct itself back to the center from left side on highway speed, from right side it corrects a bit. On a standstill or low speeds you cant really feel it and wheel corrects itself back. I could probably blow the wheel to the left on highway speed :/ We plugged OBD also, steering sensor is reading degrees etc correctly.
What do you think, did I damage the steering rack? Is there somekinda valve/solenoid that is stuck open etc?
English is not my first language and I pretty much wrote that in a hurry, if possible I will try to make a video to get a better glance at it and will try to answer to your questions ASAP and more clearly!
mhoran89
11
07-19-2022 06:51 AM
bbchen909
Q5/SQ5 MKII Discussion
36
04-30-2022 09:53 AM
deuces
Q7 MK 1 Discussion
10-03-2020 03:07 PM
qqq1970
A6 (C7 Platform) Discussion
05-31-2019 02:57 AM
quattromano
10
05-07-2004 02:32 PM
Quick Reply: A6 C6 steering wheel way too light on highway speed when turning left.
