A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 09-02-2016, 02:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Engine Guides
Print Wikipost
Post valve cover gasket replacement errors
Old 07-03-2015, 07:44 PM
am_ver's Avatar
Default Post valve cover gasket replacement errors
Took the car to an indy to get the valve cover gasket replaced. The passenger side gasket was replaced (which I believe is bank 1). The orange CEL came soon thereafter and the shop was about to close when I was leaving.
Its pretty obvious that something in that airbox area was not put together correctly. Any ideas on what I should check or start with?
008304 - Intake Manifold Tuning Valve (Bank 1): Stuck Open
P2070 - 006 - Short to Plus
Freeze Frame
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 18
Reset counter: 40
Mileage: 219213 km
Time Indication: 0
Date: 2015.07.03
Time: 17:46:42
Freeze Frame
RPM: 2976 /min
Mass Air / Rev.: 468.7 mg/str
Temperature: 94.5°C
Part Throttle
Absolute Pres.: 904.4 mbar
Speed: 88.0 km/h
008212 - Intake Manifold Flap Position Sensor (Bank 1): Electrical Malfunction
P2014 - 007 - Short to Ground - Intermittent
Freeze Frame
Fault Status: 00000010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 38
Mileage: 219213 km
Time Indication: 0
Freeze Frame
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: -40.5°C
Engine Off
Voltage: 0.000 V
Speed: 0.0 km/h
004176 - Bank1; Exhaust Cam Adjustment Valve 1 (N318): Open Circuit
P1050 - 009 - Open or Short to Ground - Intermittent
Freeze Frame
Fault Status: 00000100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 38
Mileage: 219213 km
Time Indication: 0
Freeze Frame
RPM: 0 /min
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
008198 - Intake Manifold Flap; Bank 1: Stuck Closed
P2006 - 006 - Short to Plus - MIL ON
Freeze Frame
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 219214 km
Time Indication: 0
Date: 2015.07.03
Time: 18:39:20
Freeze Frame
RPM: 2176 /min
Mass Air / Rev.: 348.8 mg/str
Temperature: 93.0°C
Part Throttle
Voltage: 2.860 V
Speed: 42.0 km/h
008199 - Intake Manifold Flap; Bank 2: Stuck Closed
P2007 - 006 - Short to Plus - Intermittent
Freeze Frame
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 219214 km
Time Indication: 0
Date: 2015.07.03
Time: 18:39:20
Freeze Frame
RPM: 2880 /min
Mass Air / Rev.: 485.1 mg/str
Temperature: 72.0°C
Part Throttle
Voltage: 1.500 V
Speed: 38.0 km/h
Readiness: 0000 0000
Old 07-04-2015, 01:33 PM
saifxnyc's Avatar
You need engine work done properly by someone who knows Audis my indie guy works ar the dealer ship and has his own garage only save about 25 to 30 % but that is a lot on labor. He worked on the manifold control runner on the manifold it is a common problem with this car with the carbon deposits! mines did it at 70K....i was also getting 5 MPG if that helps...
Old 07-05-2015, 09:56 AM
raj99's Avatar
Hi am_ver,
Have you seen this thread: https://www.audiworld.com/forums/q7-...-open-2863374/
Looks like it could be a control linkage that came undone...take a look and let us know what you find. Can't believe it's a coincidence whilst doing the VCG, since lots of things need to be moved while doing it. BTW, would have recommended you do the plugs and the air filter, if they needed to be done at the same time.
Old 07-05-2015, 11:31 AM
BillBoost37's Avatar
A coincidence like that would have me looking for the connectors to the valves. Likely it's in the back of the motor and should be at a spot where it'll keep the VC from coming out. Therefore they unhooked it and it was just out of sight when they put it back together.
Old 07-05-2015, 12:22 PM
am_ver's Avatar
Thanks guys for the tips!! I started with taking the air intake apart, re-installing the air box and the filter. Checking for loose electrical connectors (one by the accordian did seem loose). Took it for a test drive. The interesting part was that the light never came on in the initial ride - stop the car for a few minutes and BAM, comes the orange CEL.
So, one of the other things I had the indy do was replace the power steering fluid return hose. And right below that is the vacuum line. Given how brittle that line is, I bet the indy mechanic took a piece of the vacuum line while struggling with the clamp of the hose - bet he didn't even realize it.
Checked for continuity of the vacuum line and the vacuum line came out and appeared to be connected to nothing. Replaced the line, took her for a spin and no CEL.
https://www.audiworld.com/forums/a6-.../#post24276198
Thank you Audi bug!!!
My advise to anyone seeing the P2006/P2007 error codes at the same time: check your vacuum lines for continuity/cracks.
Old 07-05-2015, 03:07 PM
I'm not up on my terms as I am new to Audis. What is an indie ?
Old 07-05-2015, 03:25 PM
raj99's Avatar
I believe saif is referring to and independent mechanic, when he stated "indie"
Old 07-05-2015, 04:45 PM
Thanks.. all I could think of was indie music.. which .... anyone born before 1980 would just call Alternative..lol
Count Almasy
11-02-2008 02:01 PM
Audi Logic
Audi 100 / A6 (C4 Platform)
07-15-2005 01:51 AM
generaljdog
02-28-2004 03:59 PM
Skywalker
07-08-2000 07:20 PM
puzzled
09-01-1999 04:30 PM
Quick Reply: Post valve cover gasket replacement errors
