Problem installing Dension Gateway
Hi
I bought a Audi A6 -06 and wanted to be able to stream music from my iphone to car stereo.
I got a Dension Gateway (GW52MO1) and installed it and there is some problems.
I got a red screen, MMI basic and a single cdplayer and i only got 4 buttons around the multimedia wheel.
After i installed the Dension the multimedia wheel stopped working.
The blue LED on the Dension is blinking when in on mode, if i switch to bypass its off.
I can connect my iphone trough bluetooth and make calls and i can play music with the aux 3.5mm.
So, do i need to code something with my vag-com? What shall i try next?
Please let me know if you have any idees.
Best regards
Alexander
Best regards
Alexander
Hi
Best regards
Alexander
Best regards
Alexander
FWIW, are you sure that you installed everything correctly? If not, there's a GREAT installation video on youtube by Enfig here's the 2nd one:
<iframe width="560" height="315" src="//www.youtube.com/embed/gz_1FSEqpng" frameborder="0" allowfullscreen></iframe>
As Schwartz mentioned, make sure your MMI is up-to date. Also, make sure that you have a good battery.
cheers
You have the wrong Denison Gateway. You posted that you are trying to instal GW51MO1. For MMI Basic you need GW51MO2.
Audi - Denison Compatibility Chart
OP, ouch, sorry to hear you went through the entire install...at least you'll be quicker to install the 2nd time around
Hi guys
Sorry, but i have the GW52MO1, and that is right?
I now have the dension to have a solid blue led, ( i had the cable from the connecter port in the wrong input)
But i cant see any other sources under "cd changer", only gw aux.
Gw aux is working but i dont want to use a 3.5mm cable.
Could it be an update for my mmi system that is the solution?
Hi guys
GW52MO1 (which you have) won't work with MMI Basic no matter what you do.
what version mmi you have?
if i recall right some update had something to do with audi AMI system...so perhaps
that one also affects dension...(long shot)
cheers/H
cheers/H
Joe McPhee
07-24-2018 05:44 AM
WECoyote-SuperGenius
NY / NJ / CT Discussion
01-11-2008 03:43 PM
