Question on ATF fluid change in 2005 A6 3.2 Quattro
Last year I tried changing the ATF fluid but could not access to couple of pan bolts.
So at that time, I decided not to take the pan off, so I just drained the ATF fluid
and refilled it.
I would like to take the pan off if someone and can post pictures DIY of how to
take off the pan bolts which I did not easy access to.
This is for a 2005 Audi A6 3.2L.
My fluid is the original golden fluid.
Any help would be great
Thks
and refilled it.
Thks
and refilled it.
Thks
and refilled it.
Thks
https://www.audiworld.com/forums/a6-...fluid-2816950/
I did mine 2 years ago and also replaced the filter, gasket, etc. Be sure to refill with the correct zf fluid for your motor, I used zf lifegaurd 8.
Also I had my Indy do it and also had the diff fluid and center changed as well.
mcmorariu
12-29-2013 11:44 AM
hotm6654@hotmail.com
12
07-13-2009 02:29 PM
spoon2000
10-01-2008 10:59 PM
jguthrie
10-10-2005 03:00 PM
