question on vehicle ride - AudiWorld Forums
A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007-present
Old 07-03-2014, 03:02 PM   #1
Default question on vehicle ride
I have a 2007 3.2 with 63k miles. They have recently just paved my route home and there are minor road undulations. It seems I can feel every one of them. Over regular bumps car act fine. Shocks pass the bounce test. Is this normal or is this car in need of shocks or other suspension components. I have owned car since it was 6 months old and never noticed this before.
raaizin is offline   Reply With Quote
Old 07-03-2014, 04:54 PM   #2
raj99's Avatar
It's very common to have the struts go on these cars about that mileage and age of vehicle. get some fsd and you'll be fine.
also check your suspension components for wear since bushings go bad from time to time
raj99 is online now   Reply With Quote
Old 07-04-2014, 03:51 AM   #3
Tech Guru
4Driver4's Avatar
Quote:
Coilovers, you mean. Struts never go bad on the C6. ;-)
4Driver4 is offline   Reply With Quote
Old 07-04-2014, 07:37 AM   #4
I've always wondered if the bounce test really works. I mean, my car passes the bounce test but, damn, the suspension just doesn't feel right. It's a bit harsher than it needs to be as if the suspension is worn.
On top that I've started getting the clunking from the front end. All the bushings look good though. Although the sway end links look like they need to be replaced, I can't imagine that causing all the clunking.
enoch861 is offline   Reply With Quote
Old 07-05-2014, 05:49 PM   #5
frankinstyn's Avatar
The Sway end links caused all that clunking on mine. In fact it was only one of them. The car felt much better after I swapped that out. Mine is with air suspension but I don't think that would make much difference in this instance.
This is the part that was bad. Cost me all of $30 to fix. Didn't even have to re-do my alignment.
frankinstyn is offline   Reply With Quote
Old 07-06-2014, 01:44 PM   #6
Interesting.
<strike>Where did you purchase it from?</strike> For $30 bucks I might as well replace both.
RockAuto has some for $18 a piece with bolts. I'll order 2 and see if that helps.
Old 07-06-2014, 02:15 PM   #7
raj99's Avatar
Quote:
Originally Posted by enoch861 View Post
Interesting.
Where did you purchase it from? For $30 bucks I might as well replace both.
I bought my set from rmeuropean.com buy better quality since they take some abuse. I went with the lemforder ones which are oem.
Thread Thread Starter Forum Replies Last Post
2016 S8 Ordered and some questions... Jay-S8 A8 / S8 (D4 Platform) Discussion 16 09-28-2015 09:42 AM
:: ECS Tuning :: B6/B7 S4 ECS Assembled Heater Core Refresh Kit ECS Tuning-Audi S4 (B6 & B7 Platforms) Discussion 0 09-03-2015 01:45 PM
Need Help with Winter Tire/Wheel set at Tirerack mkirkpatrick Wheels & Tires Discussion 2 09-03-2015 09:31 AM
:: ECS Tuning :: Assembled by ECS Audi B6 A4 1.8T Quattro Brake Service Kits. ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-02-2015 12:39 PM
:: ECS Tuning :: MKI TT ECS Assembled Control Arm Kit Collection ECS Tuning-Audi TT (Mk1) Discussion 0 09-01-2015 01:25 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
