"Radio not installed" after failed MMI update!
Hello,
C6 2005 3.2Q
MMI SW: C6-HU 6350 05.0.0 0413 (very old version)
Burned 3 images to 3 CD-R on 1x speed.
MMI 4L0-998-961 5570 CD1
MMI 4L0-998-961 5570 CD2
MMI 4L0-998-961 5570 CD3
I didn't have battery charger, so i was doing this with engine running. Inserted first CD, get to "Reading Meta-Information" and got "Drive error! Metainfo cannot be analysed! Try again or Cancel"(i was reading that this can happen even with original cd and you need to try again), so i tried again and update started. There was standard update message including "Upgrade from 290 to 330", it finished without problems in 2-3 min. After, it automatically started next upgrade - "Upgrade from 330 to 470(i can be wrong with these numbers)", but nothing happened, percents was hanging on 0 and notification popped out - "Drive error, Metainfo cannot be analysed!" or something similar, didn't make photo. There was two options, try again or cancel, tried couple times with no success and canceled, it popped out warning message that cancel can ruin system, but I didn't have other options as i was getting drive error all the time. So it done cancellation process what was taking some 5 min. After i restarted MMI and saw "Radio not installed", also there is no light on CD changer buttons, but CD changer works fine, ejects, inserts cd's and plays audio cd's without problems.
After that I tried to start update process again, but now all the time I am getting "Driver error! Metainfo cannot be analysed! Try again or Cancel" i tried a lot of times, even chaged slots for CD. Tried to unplug communication fuses to restart cd changer, didn't help. Still no radio and no light for cd changer buttons.
I was too lazy to order original cd's and wait for delivery, now have this problem.
Searching for ideas what caused this problem and how to fix it before going to dealer.
Somebody knows where can be problem for radio and cd changer button lights?
I am thinking that problem was caused because of bad CD and i messed up radio and changer with half update. Maybe i need to try original CD's?
C6 2005 3.2Q
Did you read the stickie thread at the top of this forum that warns that old versions must be updated in two steps? I'd try loading the mid-version now. If successful, retry the version you used.
https://www.audiworld.com/forums/a6-...steps-2607361/
I didn't read that topic, but I searched before and find another topics, where people was writing that they have done successful upgrade from version what i have to 5570 without using mid versions. Also i forgot to mention that I am upgrading European version if it makes difference.
a_very_naudi_guy
12
04-24-2018 11:47 AM
