RPM flactuates on cold start ups, hissing sound (with video)
Hi guys,
I have a 2006 Audi A6 2.4 v6. Every morning when I start my car the rpm fluctuates. It usually happens for about 5 mins and after the engine is hot, it goes away. When the rpm drops, the speedometer lights will also get dimmer. I opened the bonnet and I noticed that there is a hissing sound (i am not sure how to describe it, but pls refer this youtube video). The RPM drops when the sound can be heard. I initially thought it was a vacuum leak, but my mechanic checked and he said there is no leak. There is also no error codes. My mechanic is stumped, and so am I! I was thinking it could be the MAF, but if it were, there should be an error message rite?? Thanks in advanced
YOUTUBE VIDEO
YOUTUBE VIDEO
Hi guys,
YOUTUBE VIDEO
YOUTUBE VIDEO
could not just guess what is going on in there, have it scanned with VCDS
Are you sure that the mechanic really checked all of the vacuum lines? I have a 2005 4.2 and it is my understanding that you need to remove the manifold to get to some of the vacuum lines. I had the hissing noise you described a few months ago and after removing the manifold determined that it was one of the vacuum lines. After replacing the vacuum lines the hiss noise went away.
i actually changed the intake manifold 2 months back. i will ask him to check tomorrow. Tq According to my mechanic, he suspects that it has something to do with a sensor.
But agree with Kevin that vacuum leaks are pretty common and a relatively easy fix. Do a smoke test if unsure and you will find the culprit. Also, that engine seems to be 'ticking' quite a bit...
no the engine is no ticking. the video makes it sounds worse than it really is. also it was a cold start, once it warmed up, the sound is reduced.
back to the hissing sound, my mechanic has checked all of the hoses, and there is no leak. its a real pain to diagnose as it only happens during cold start.
btw what is a smoking test?
