A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Rear bumper removal help.
Old 02-17-2011, 01:24 PM
audia6s's Avatar
Default Rear bumper removal help.
I want to install parking sensors on my 08 A6 and wanted to see if anyone has ElsaWin or any other info which can assist me in disassembling rear bumper. Thanks.
Old 02-18-2011, 03:05 AM
audia6s's Avatar
Originally Posted by royclark
15 FIXINGS HOLD THE REAR BUBPER ON.
WHEN YOU HAVE REMOVED ALL OF THE FIXINGS, GIVE THE SIDES OF THE BUMPER A SHARP PULL DOWNWARDS AND THE BUMPER WILL SEPARATE FROM THE BODY.
PULL THE BUMPER REARWARDS.
I PLACED A DUVETT ON THE FLOOR BELOW THE BUMPER.
FINAL RESULT
Thanks for the info. Where are the fixings located? Seems like you reply with pictures (i see tags in html code) but I am not seeing the images on neither of your replies, here and on my parking sensors post. Thanks
Old 02-18-2011, 01:50 PM
audia6s's Avatar
Yes, thank you, this can't get more detailed. I will install next weekend.
Old 02-18-2011, 04:12 PM
am_ver's Avatar
Can you please take pics and do a DIY? thanks!
Old 02-18-2011, 04:28 PM
audia6s's Avatar
It's already been done by "royclark"
https://www.audiworld.com/forums/sho....php?t=2799074
Old 08-17-2012, 07:10 PM
audia6s's Avatar
Anyone have pics on how to remove rear bumper? I already done this last year but need to replace one sensors but somehow Roy's pictures are gone
Old 08-17-2012, 08:00 PM
cebo0650's Avatar
Have a look at the attached PDF, it should help
File Type: pdf
Old 08-17-2012, 09:16 PM
audia6s's Avatar
Awesome. Thank you!
Old 08-18-2012, 04:04 AM
royclark's Avatar
When you have removed the rear bumper, you will see that the positions for the reversing sensors are marked.
I used Cobra sensors. (Off ebay)
Just follow the instructions and you can't go wrong.
I drilled the four holed (20mm) with a steped drill.
Trace the reversing lighrt wire. to get your signal from.
It is connected to the reversing light wire. (See arrow marked Reversing light wire) Put the gearshift into reverse then, with a circut tester find the live wire, If its the correct one the test light will go out when you take it out of reverse.
The four sensor wires are run into the trunk through the rubber grommet (shown here - see arrow - through grommet) THIS GOES DIRECTLY INTO THE TRUNK.
alvocado (04-15-2022)
Old 08-18-2012, 09:53 PM
audia6s's Avatar
Got everything fixed today. Thank you once again.
Quick Reply: Rear bumper removal help.
