Satellite Radio Linking Problem 2006 A6
I just bought a used 2006 A6 Quatro S-Line that has satellite radio installed. I activated it with Sirius XM, and have never been able to receive a consistent signal. The radio sounds choppy, echoey, or is absent altogether, displaying only 'Linking' for long stretches of time. I have had the signal refreshed over and over again, which takes up to 20 minutes to even start working if it works, and does not reconnect if the car is turned off. Sirius says their signal is getting through just fine. My AM/FM and NAV work just fine. Any ideas?
it sounds echoey?? it could be your radio module
if it doesnt echo in FM or CD mode
then most likely u are having linking issues
i would say your antenna cover has developed a crack and moisture has slowly degraded you sat radio board of your antenna.
there is a TSB
im having the same issue do a search with my name and keyword antenna and u will learn about the issue
there is a TSB
Did you resolve this issue?
the solution
http://www.autoradiodvdgpstv.com/use...-Manual-H8.rar
Just quoted $900 repair of antenna
I have the sat. Linking problem on my 2013 Q5. They say it's a problem internally to the antenna and need to bnb replace entire antenna. Electrical issue.
My first C6 was an '06. I had constant linking problems. I checked with a local Indy AUDI guy and he told that there was an upgraded receiver that worked much better with SiriusXM. I forget the pn's but the newer reciever works much better. I believe the early receivers may have been Sirius or XM specific and not worked well after Sirius & XM merged.
