Strange "rumble" from right rear
2005 A6 4.2
182k miles
Unsure of history, rest of the car is absurdly clean and the car is OBVIOUSLY well taken care of.
Problem ->
Driving (at any speed 20+, probably happens at all speeds) causes intermittent (once every 30 - 60 seconds, its truly random) rumbling or shuddering from right rear tire. The best analogy is it feels like driving over a highway "rumble strip", but it is ONLY the back right tire. Its more "annoying" than "violent" and doesn't make a ton of sound.
Tire is new, wheel is round. Tire is balanced fine, that was just checked.
My homework always leads me to "get your tire balanced". That is NOT the issue. I have searched quite a bit, I just cant find it.
Any help is GREATLY appreciated.
182k miles
Problem ->
Had a similar problem on my Passat, turned out a blown shock caused the most bizarre tire wear ever. Bout drove me nuts until I took off the wheel and it looked like someone had taken a belt sander to the inner tread in about 6 places - they were just flat! Could not see anything wrong from the outside. Strangest thing was it was intermittent!
HTH
-Tom
HTH
-Tom
HTH
-Tom
HTH
-Tom
could a shock issue really be intermittent though?
Ok, I took a look at it myself.
The wheel hub shifted when I took the wheel off, pretty darn sure thats NOT supposed to happen.
Could a faulty wheel hub cause these issues?
That's the weirdest part (for me) is it came and went at random even before the tire got flat spotted. I think it's akin to sympathetic vibration, it only happens at certain speeds, with the wheel's vibration set off by a certain particular set of tiny oscillations (bumps) and just tiny imbalances of the assembly.
Obviously, you've found the cause of yours, hopefully the shock is OK.
2000 A6 2.7t 6m
04-02-2007 12:01 PM
DerAudiA4
08-05-2005 07:40 PM
RTinNYC(again)
19
07-30-2001 11:01 AM
