A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Sunroof Won't Open
Old 06-19-2011, 03:55 PM
thehedge's Avatar
Default Sunroof Won't Open
2005 A6 3.2L with 105K
Went to use my sunroof for the first time this summer. Would have been a nice day for it. When I turn the **** for it open, the rear of the sunroof drops down, begins to slide and then stops and reseals the window.
It still opens correctly when using the tilt (moon roof?), just won't slide open.
I was able to find lost of posts about sunroofs which won't close but didn't see the reverse situation.
Any suggestions on what to try myself before having the shop charge me for something easy to fix?
Thanks
Old 06-19-2011, 04:40 PM
jeffry's Avatar
in your manual there are the instruction how to open manually and where are the fuses...
Old 06-20-2011, 02:22 PM
am_ver's Avatar
While we are talking about sunroof issues, I have just the opposite. After opening the sunroof, the roof doesn't close - it reaches the last part where the wind deflector is pressed down; and right there, the sunroof reverses direction and opens all the way. I can make the roof close till the last click on the dial - no problem, but the '0' position is where the roof just attempts to close and then reverses. It is almost like a bad pinch protection.. or something is getting stuck.. second time this issue has occurred, and then after a lot of tries, the roof closed.
Now I'm just afraid of opening the roof. I know there is a tsb for roof adaptation process - could that be a solution?
Old 06-20-2011, 04:22 PM
jeffry's Avatar
Check out this website and look for sunroof http://www.uberlame.com/a6_tsb/
Old 06-21-2011, 04:35 AM
pcamaj's Avatar
am_
mine does the same thing at times , and i have the solar one... eve a 2010 a4 they had given me once as a loaner did the same thing. but if u just turn the **** back and forth once or twice it will close...
"AUDI" lol
hevnsnt
16
03-18-2022 03:43 PM
jcdb4
09-16-2017 05:33 AM
swifter
04-29-2009 01:12 PM
Vic
01-05-2007 11:37 AM
Tre-Z
Audi 100 / A6 (C4 Platform)
08-15-2003 09:30 AM
Quick Reply: Sunroof Won't Open
