Think a timing chain tensioner failed, need advice.
Hi Everyone,
I think one of my timing chain tensioners failed on my 2008 A6 4.2L. VCDS initially gave me the following codes:
After clearing codes I get:
The p0016 (bank 1) makes more sense to me than the p0019 (bank 2) that I was initially getting because all 4 cylinders on bank 1 were misfiring. I also tried swapping the cam sensors side to side to see if the code switched sides, but it stayed. I'm basically ruling out the speed sensor (crank) as a possibility because the problem seems to be effecting only the one side of the motor except for the oddity of the p0019 (bank 2) code I initially received.
1. Does anybody have any opinions of further things to check?
2. Assuming it's a chain tensioner, does anybody have a shop recommendation near the Northwest Suburbs of Chicago?
Thanks in advance for looking and any feedback you might have!
Code:
000025 - Bank 2: CMP Sens 4 (G301) / Engine Speed Sensor (G28) P0019 - 002 - Incorrect Correlation - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 153922 km Time Indication: 0 Date: 2015.06.02 Time: 17:38:33 Freeze Frame: RPM: 1470 /min Load: 13.7 % Speed: 48.0 km/h Temperature: 102.0°C Temperature: 31.0°C Absolute Pres.: 990.0 mbar Voltage: 13.843 V 000017 - Bank 1: Camshaft A (Intake) P0011 - 004 - Retard Setpoint not Reached (Over-Advanced) Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155336 km Time Indication: 0 Date: 2015.06.23 Time: 18:16:43 Freeze Frame: RPM: 2529 /min Load: 81.1 % Speed: 72.0 km/h Temperature: 99.0°C Temperature: 36.0°C Absolute Pres.: 990.0 mbar Voltage: 13.843 V 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155337 km Time Indication: 0 Date: 2015.06.23 Time: 19:38:17 Freeze Frame: RPM: 2074 /min Load: 54.5 % Speed: 15.0 km/h Temperature: 95.0°C Temperature: 66.0°C Absolute Pres.: 990.0 mbar Voltage: 13.335 V 000769 - Cylinder 1 P0301 - 001 - Misfire Detected Freeze Frame: Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155337 km Time Indication: 0 Date: 2015.06.23 Time: 19:38:17 Freeze Frame: RPM: 2074 /min Load: 54.5 % Speed: 15.0 km/h Temperature: 95.0°C Temperature: 66.0°C Absolute Pres.: 990.0 mbar Voltage: 13.335 V 000772 - Cylinder 4 P0304 - 008 - Misfire Detected Freeze Frame: Fault Status: 01101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155337 km Time Indication: 0 Date: 2015.06.23 Time: 19:38:17 Freeze Frame: RPM: 2074 /min Load: 54.5 % Speed: 15.0 km/h Temperature: 95.0°C Temperature: 66.0°C Absolute Pres.: 990.0 mbar Voltage: 13.335 V 000771 - Cylinder 3 P0303 - 001 - Misfire Detected Freeze Frame: Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155337 km Time Indication: 0 Date: 2015.06.23 Time: 19:38:17 Freeze Frame: RPM: 2074 /min Load: 54.5 % Speed: 15.0 km/h Temperature: 95.0°C Temperature: 66.0°C Absolute Pres.: 990.0 mbar Voltage: 13.335 V 000770 - Cylinder 2 P0302 - 001 - Misfire Detected Freeze Frame: Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155337 km Time Indication: 0 Date: 2015.06.23 Time: 19:38:17 Freeze Frame: RPM: 2074 /min Load: 54.5 % Speed: 15.0 km/h Temperature: 95.0°C Temperature: 66.0°C Absolute Pres.: 990.0 mbar Voltage: 13.335 V
Code:
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28) P0016 - 001 - Incorrect Correlation Freeze Frame: Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 155352 km Time Indication: 0 Date: 2015.06.23 Time: 20:05:43 Freeze Frame: RPM: 675 /min Load: 38.4 % Speed: 0.0 km/h Temperature: 104.0°C Temperature: 50.0°C Absolute Pres.: 990.0 mbar Voltage: 12.954 V
IIRC the 4.2l engine will need to be pulled for timing chain tensioner replacement. Certainly appears to be your problem. Had similar codes on a VR6 that turned out to be a timing issue (solenoid valve jammed - not applicable to your engine) and not failed sensors.
mc_hotmail
2.7T V6 Discussion
10-27-2012 02:26 AM
