Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Engine Problems by Symptom
Timing chain noise
#22
Where does the 8 degree "service limit" come from?
I understand that it is the deviation between the intake & exhaust cams on each bank.
I'm just wondering where the actual limit came from?
I didn't find anything in ELSA or Bentley about it.
I'm just wondering where this "prudent judgement" service limit came from.
#23
#24
Well, I got my VCDS block 93 readings today:
position I1 I2 E1 E2
Cold@idle 0.4 6.0 3.0 1.1
Hot@idle -0.4 5.6 2.3 0.8
Hot@3Krpm 0 6.0 2.6 1.1
That's the long & short of it. Not too bad, but not too good...
This gives me a baseline@153K miles. Bank 2 is not faring too well but, now, I can watch it.
I think the noises, that were originally concerning to me, were the engine's characteristic to speed up to an 1300rpm idle(in neutral) for a minute or two when cold, after it's running about 20 seconds. As soon as you put it into D or R, the electronics take it right back down to a 900rpm idle. On my car, 1300rpm cold idle is a lot noisier than 900rpm. That noise raised my cautious concerns.
Anyway, I'm going to start eBay shopping for the tools to change the top tensioners now, & monitor these readings. I can buy the tools, put them on a shop shelf, & be ready.
I have almost same values as you.. They been so the whole time I owned the car since hmm.. 2008.. And the car had only 28000 miles... And no start up rattle so far.. =)
Cheers /H
#25
I have been trying to find out how fast the wear progresses & just where the 8 degree limit comes from.
I'm going to monitor my readings, to look for rate of charge & any acute jump, before I immediately change out the tensioners. However, I am going to gather all the physical & intellectual tools to do the job now. I'll put them on the shelf, in my shop, until it's time to do the job. It seems that I could always get new tensioners overnighted, but the tools could be a little tougher.
#26
I spoke with one fellow, earlier this week, whose '05 C6 4.2 upper tensioners wore out. He drove it until his deviations were over 12! He told me that took quite a while, as the car aged. He traded it in, limping, at 167k miles.
So, I'll continue monitoring mine, more closely as it pushes the service limit.
#27
How long have you owned the car? Is it a new noise? If it is a new noise then the claim that they all make that noise is probably wrong. I agree with raj, post a clip so that we can hear the noise. I had the timing chain rattle on my 4.2 and I would not have described it as a squeal.
#28
It sounds like the tensioners.
Get the engine scanned, & it'll tell you for sure.
There's a great thread on how to do the change out, if it's your upper tensioners.
About $500 to do the job yourself, w/OEM tensioners. About $1000-1500 to have them done, if it's just the upper ones.
#29
Address 01: Engine (4F1 910 559 E)
14:14:12 Group 093: Camshaft Adjustment (Adaption Values)
0.0°KW Phase Position Intake Bank 1
4.5°KW Phase Position Intake Bank 2
1.5°KW Phase Position Exhaust Bank 1
1.5°KW Phase Position Exhaust Bank 2
Local Audi will only do the whole job including chain - $9K. Not something I could tackle.
#30
Well,
$9k ??!?!
I can swap a used and rebuilt motor for that price. Get another quote.
