Last edit by: IB Advertising
- Audi A6 C6 How to Change Manual Transmission Fluid<br>Step by step instructions for do-it-yourself repairs.
- Audi A6 C6 Quattro System Fluid Change<br>Step by step instructions for do-it-yourself repairs.
Trans, diff and transfer case fluid change
#21
Have you contacted your local audi dealership and simply asked them for your particular VIN which transmission fluid you need?
BTW, it is HIGHLY unlikely that they will have done any transmission fluid change to your car, since most dealerships swear by the line 'it's a LIFETIME fluid'. However, some actually have an ounce of logic and admit that it should be changed. CTC seems to know what they are doing, so they certainly are SMEs (subject matter experts) regarding ZF trannys.
Good luck
Good luck
I was confused about the Lifeguard 6+ fluid so I sent a question the thectsc.com support email and got the following reply:
LifeGuard 6+ is no longer sold by ZF, LifeGuard 8 is its replacement.
Especially if you have the transmission software updated there is no issue.
We have not put together Audi fluid change kits as of yet.
Best regards
Klaus
A little less murky I suppose.
Best regards
Klaus
#22
Best regards
Klaus
Best regards
Klaus
Also you might want to check this out and see if it's still available: http://classifieds.audiworld.com/sho...t/10486/cat/22
#23
Good luck
Good luck
Whatever. I'll go with the Lifeguard 8, like thectsc recommended and not go with the dealers recommendation.
Makes me wonder how many Audis suffer premature transmission failure from the magical lifetime fluid. I guess the same goes for other manufacturer's saying the same thing.
Not sure what the point of the TSB on the transmission was about. That recommended updating the software and then flushing the old fluid out and replacing with the updated fluid.
This would be why I try at least understand what is needed and try to do the work myself.
#24
To add one more data point (not clarity, just data ). I called my local deale and asked for the part # for the ATF and how much a fluid change would cost. He answered as expected that it's lifetime. The part # he gave me is: G060162A2, which equated to Lifeguard 8.
I said that I thought ZF recommended changing every 60k miles and he said that Audi fluid is 100% synthetic and that's why it doesn't need changed. So Audi fluid is not Lifeguard fluid and Lifeguard is not 100% synthetic?
The wisdom on The Google seems to say that the lifetime fluid philosophy is that as the clutch plates wear and thin, the material is absorbed into the fluid and it keeps the clutch plates from slipping. Replacing the fluid will remove the worn material and cause slippage.
I just can't get over $45/liter fluid.
#25
just get the fluid and be done with it. Yeah it's pricey, but you only do it once every 4-5 years...so amortized over the length of time or mileage, it's not much. Plus you'll have piece of mind.
BTW, mine only took 5 quarts, so all you need to buy is 6 quarts (to be on the safe side).
have fun
have fun
#26
And lifetime fluid, i work at a repair shop, its my number one service i get customers to do. 80k fluid is jet black, nasty, trans shifted alittle harsh and delayed. After a change, man, perfect, smooth shifts with no trouble. Definatly change it heres a cheaper source than the dealer.
http://www.thectsc.com/index.php?p=p...d=193&parent=0
#27
I completely agree that lifetime fluid is a completely myth (I should have clarified that I don't agree with, just summarizing what I found on The Google). At this point, I am definitely going to change all the drivetrain fluids out. I was going to use Lifeguard 8 from thectsc for the transmission.
#28
I am gathering supplies for a complete driveline fluid change and wanted to use the collected wisdom on the transmission filter. Looks like 2 options. Thectsc sells a combined pan/filter for $142. There are other places that sell just the filter for ~$70. Both options need a gasket.
I'm inclined to just get a filter and gasket, but ctsc must sell the combined pan/filter version for a reason. Does the combined make it easier? I've changed plenty of trans filters.
Any thoughts on that?
#29
I did this a little while back and the only thing I can forsee the need for a new pan is due to damage to the current one on your car. If the current one is structurally sound, I can't imagine any need for a new one. BTW, the pan and filter are independent of one another, therefore buying the whole assembly does not have any advantage over just buying the filter.
For the record, I replaced with ZF8, filter, and gasket only.
