Transmission oil change 50K.
#11
#15
Here is my transmission info form VAG-COM:
Address 02: Auto Trans
Control Module Part Number: 4F2 910 156 D
Component and/or Version: AG6 09L 3,2 FSI USA 0010
Software Coding: 0000002
Work Shop Code: WSC 02325
Advanced Identification
Serial number: 4113583
Identification: ZFS-005
Revision: --H01---
Date: 24.11.05
Manufacturer number: 0087
Test stand number: EOL7
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Software
477477R2222
1267017177
Misc.
Hardware number: 09L 927 156 A
Immo IV Challenge: DC 1D D0 3C
All i want to do is: dropt the pan, change filter, add 4-6 bottles of fliud and be done.
No my q is what kind of fluid should i use:
(NO) Gold-G052162A2-$15 (for the C5 and also known as Esso LT 71141)
(YES)Gold- G055005A2-$35 (standard type for 2005-2007 C6 & tipronic trans)
(MAYBE) Green-G060162A2-$47 (standard type for 2008-up but need software update if you upgrading to this type)
(NO)Blue-G055162A2- $80 (for 6HP26A61A2 trans with W-12 engine only)
I think my best bet is just to use Gold- G055005A2-$35 or can i use Green-G060162A2-$47. Can i mix them up if i change just the half of the fluid.
I might consider transmission flush (and maybe using blue) if i knew that i can do software upgrade myself. How much upgrade would cost at dealer?
Thank You.
Revision: --H01---
Date: 24.11.05
Flash Status
Software
477477R2222
1267017177
Misc.
Thank You.
#18
Blue is the fluid specified by Audi in its TSB. Blue is not limited to the W12.
http://uberlame.com/a6_tsb/Transmiss...ween%203-4.pdf
I still haven't ordered and am now unsure if should go blue via the dealer or not.
#19
Quite an informative thread here. I can't comment much in the way of technicals but I did notice one way I might contribute. Bariukas commented that blue atf was $80 at the dealer. I've been scratching my head trying to figure that out since we have G055162A2 (blue) for $38.54. So if you want to DIY this and only goto the dealer for a software update we can help save you some serious money.
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
