A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Unstable idle rpm, A6, 3.2AUK engine, quattro,2005
Old 08-25-2014, 10:35 AM
gog22's Avatar
Default Unstable idle rpm, A6, 3.2AUK engine, quattro,2005
Unstable idle rpm, when engine temperature exceeds 75 Celsius degree
there are no DTC errors
But that was tested and did not help
1) cleaned throttle body
2) replaced throttle body
3) adapted throttle body
4) Replace the valve (Pressure Control Valve (PCV) http://www.ecstuning.com/Audi-C6_A6-...ake/ES2535189/
5) Replaced for testing MAP sensor (http://www.ecstuning.com/Audi-C6_A6-...ake/ES2678229/)
6) VCDS told me that i have small amount of misfires (3-5) does this affect?
After this rpms, 5-10 min later, engine is turning with increased speed but stable,Instead of 650 jumps to 900
Drops are seen while driving, but no actual feeling. For instance on same turning, it jumps from 1500 to 1400 and then goes back again
unstable rpm 3.2
Please help
Kokes
26
09-09-2023 07:23 PM
Audi-cycle
30v V6 Discussion
09-22-2017 07:55 PM
jb0814@hotmail.com
07-12-2003 10:59 AM
micke
VAG-COM Discussion
03-23-2003 02:32 PM
Quick Reply: Unstable idle rpm, A6, 3.2AUK engine, quattro,2005
