VCDS coding for enable 2011 A6 C6 Audi Driver Select
Does any one knows the VCDS coding for enable 2011 A6 C6 Audi Driver Select menu, I did the first step, enabled the hidden menu, now the Audi Driver Select menu shows up but in white color, which is can not be adjustable, I have the VCDS but need the coding to active it. really appreciate your help!
Here you go on how to enable this:
AudiEnthusiasts Vag Com
And here's specific to the 3G+: AudiEnthusiasts Vag Com
Good luck
Good luck
Good luck
Good luck
