Widdling down the possibilities...
Widdling down the possibilities...*SCAN included*
I figured instead of clogging up the board with random questions (after failed searches) I'd post about the things I'm uncovering as I go along.
Audi A6 Quattro 3.2
i was told the head gaskets might be gone on this 3.2 or worse, a cracked block. I've driven it around town... temp gauge stays consistent... doesn't run hot and no visible signs of coolant level lowering. No white smoke and no milky oil.
so I've completed tonight, the first of many tests.
#1: Block tester: cheapo way to test exhaust fumes circulating in the coolant tank. Ran to temperature and fluid has remained blue. I'll scratch that off the list.
noticeable thwacking sound coming from engine. Like plastic clicking.
Tomorrow, VCDS scan. Looking forward to throwing a log up and getting some answers.
Audi A6 Quattro 3.2
Well day two... I got a hold of a vagcom machine and plugged it in. Can't say I know what its all saying so I'll throw it on here and maybe I can get some direction.
I scanned the car with the ignition on but not running... battery is poor and needs a charge every time I switch the ignition on
It would appear, I have a very sick automobile with a plethora of faults. I am not sure if some of these show up naturally because the car isn't running. I have a steering wheel fault somewhere.
At any rate, here are the faults for Controller 01 Engine
Wednesday,29,March,2017,14:38:00:52101
VCDS Version: Release 17.1.3 (x64) Running on Windows 10 x64
Ross-Tech: Home
Address 01: Engine Labels: 06E-910-559-BKH.lbl
Control Module Part Number: 4F2 910 559 B HW: 4F1 907 559 A
Component and/or Version: 3.2l V6 FSI 0030
Software Coding: 01050109190F0020
Work Shop Code: WSC 22172 444 84536
VCID: 2B551E598ACEB5196C-807E
8 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 008 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 11
Reset counter: 40
Mileage: 301590 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 100.5°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 006 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Reset counter: 39
Mileage: 301590 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 81.0°C
Engine Off
Voltage: 9.08 V
Speed: 0.0 km/h
008309 - Position Sensor for Intake Manifold Tuning Valve (G513)
P2075 - 007 - Elect. Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 39
Mileage: 301590 km
Time Indication: 0
000838 - Camshaft Position Sensor (G163)
P0346 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 13
Reset counter: 40
Mileage: 301590 km
Time Indication: 0
Date: 2005.02.06
Time: 08:27:26
Freeze Frame:
RPM: 672 /min
Temperature: 70.5°C
Start
Bin. Bits: 00001000
Speed: 0.0 km/h
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 40
Mileage: 301590 km
Time Indication: 0
Date: 2005.02.06
Time: 08:27:26
008196 - Intake Manifold Flap; Bank 1
P2004 - 007 - Stuck Open - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 4
Fault Frequency: 9
Reset counter: 40
Mileage: 65536 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: -48.0°C
Engine Off
Voltage: 0.000 V
Speed: 0.0 km/h
000769 - Cylinder 1
P0301 - 007 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 40
Mileage: 65536 km
Time Indication: 0
005000 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00001000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 65536 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Engine Off
Bin. Bits: 00000000
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Readiness: 0110 0101
Ross-Tech: Home
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 40
Mileage: 301590 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 39
Mileage: 301590 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 81.0°C
Engine Off
Voltage: 9.08 V
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 39
Mileage: 301590 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 40
Mileage: 301590 km
Time Indication: 0
Date: 2005.02.06
Time: 08:27:26
Freeze Frame:
RPM: 672 /min
Temperature: 70.5°C
Start
Bin. Bits: 00001000
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 40
Mileage: 301590 km
Time Indication: 0
Date: 2005.02.06
Time: 08:27:26
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 40
Mileage: 65536 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Engine Off
Voltage: 0.000 V
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 40
Mileage: 65536 km
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 65536 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Engine Off
Bin. Bits: 00000000
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0000
Thanks for responding... is there anything in these scans that points directly lynto something I could fix or conversely... is there anything that says "stop driving this car"?
The first thing you should do is erase all the faults and then rescan the vehicle to see what persists. The 2 issues I see that standout are:
Go to the Ross-Tech site and you can search for the standard troubleshooting for those issues.
There a issue with the Intake Manifold Flap; Bank 1, but that was at over 200K km ago, so it may be a moot point.
OP, why don't you post an actually vid of the car running with the hood open and let us see and hear how the vehicle runs?
Here's a short clip: https://youtu.be/1CR_P_2MKf8
One things for certain, I'll need to replace the valve stem seals.
https://www.audiworld.com/forums/a6-...ement-2861500/
Thanks raj... not discounting what's been said... the tensioners were replaced and thus started this assortment of issues. Perhaps they were installed incorrectly.
The clicking noise is most prominent at the front of the engine... opposite to the tensioners.
Unfortunately I can't tell where the noise is coming from in the video clip, so perhaps you're correct that it's not the tensioners. But it doesn't sound "good".
