A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 09-09-2016, 03:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Interior Guides
Print Wikipost
Wind Noise from Sunroof no water leaks
Old 12-11-2015, 10:25 AM
DH9441's Avatar
Default Wind Noise from Sunroof no water leaks
Hello folks... my sunroof created wind noise from about 30 MPH +. I have pushed up on it while driving but no change. I have also cleaned the seals and tracs all the way around with no change. It appears that it seat level when closed.
I've done some extensive searching on this issue but it would appear I'm the only A6 owner with this issue (2008). I would really appreciate if any one could give me any insight on how to fix this. TY!!!!!
Old 12-12-2015, 02:53 PM
Trekie's Avatar
Close the sun shade and the wind noise will lessen.
Old 12-13-2015, 06:04 AM
DH9441's Avatar
Looks like the issue issue is the front of the sunroof glass needs to go up just a bit. Does anyone no how to make adjustments to the sunroof?
Old 07-20-2016, 08:52 AM
DH9441's Avatar
Update... turns out I did get water leaks as well. I hired a sunroof guy who did find the drains where clogged or partially clogged. I think when I went thru the car wash the Dryer forced water to leak thru the sunroof due to partially clogged drains. The tech made a slight adjustment to the back of the sunroof trying to fix the wind noise. However, there was no change. I still have the wind noise.
Old 07-22-2016, 03:54 PM
IndianaA6's Avatar
I've had a noisy sunroof since day one in my 05 A6...it's better with the shade closed but still annoying.
Old 07-28-2016, 11:55 AM
am_ver's Avatar
The gasket has gone brittle and needs to be changed. I've changed mine and there is no noise now. Easy DIY - you just have to push it hard inside the groove.
8E0877297
GLASS ASSY GASKET
Old 10-27-2016, 06:20 AM
DH9441's Avatar
8E0877297
GLASS ASSY GASKET
So this isn't too hard as a DIY'er? Are there any tricks to removal of the old and installation of the new?
TY!
Old 10-27-2016, 04:17 PM
am_ver's Avatar
TY!
no - its pretty straightforward. Removal is easier than install.
For the install, start on one side and push hard, and then feed and push little by little into the groove. It might seem impossible initially, but once you get it started, its very simple.
Old 10-30-2016, 05:38 AM
Elmz718's Avatar
TY!
Where can I purchase I'm having the same problem with my 2011 a6
Asarge
18
01-11-2018 09:28 AM
Huey52
05-27-2011 12:12 PM
audi231
07-15-2002 03:28 PM
jyc
03-21-2000 06:45 AM
Alex M.
08-07-1999 10:10 AM
Quick Reply: Wind Noise from Sunroof no water leaks
