would you be worried about these codes?
Was running VAGCOM on the avant today to reset the service interval reminder. happend to check the engine faults and saw this. Car seems fine though. I cleared them and will check again in a few days to see if anything comes back?
000769 - Cylinder 1
P0301 - 007 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 124751 km
Time Indication: 0
Date: 2015.09.20
Time: 08:52:25
Freeze Frame:
RPM: 2080 /min
Mass Air / Rev.: 365.2 mg/str
Temperature: 40.5°C
Part Throttle
Time: 25.6 s
Speed: 46.0 km/h
005634 - Power Supply Terminal 30
P1602 - 008 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00001000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 125359 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 87.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 124751 km
Time Indication: 0
Date: 2015.09.20
Time: 08:52:25
Freeze Frame:
RPM: 2080 /min
Temperature: 40.5°C
Part Throttle
Time: 25.6 s
Speed: 46.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 125359 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 87.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 124751 km
Time Indication: 0
Date: 2015.09.20
Time: 08:52:25
Freeze Frame:
RPM: 2080 /min
Temperature: 40.5°C
Part Throttle
Time: 25.6 s
Speed: 46.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 125359 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 87.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 124751 km
Time Indication: 0
Date: 2015.09.20
Time: 08:52:25
Freeze Frame:
RPM: 2080 /min
Temperature: 40.5°C
Part Throttle
Time: 25.6 s
Speed: 46.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 34
Mileage: 125359 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 87.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
wipe it out and see if it comes again. The missfire can be due the old sparkplug or the coil. If it repeats - simply change the plug and or coil.
Yoshimura
09-30-2015 06:20 AM
ajg617
09-06-2015 07:23 AM
anticsAK
09-06-2015 05:34 AM
anticsAK
09-04-2015 09:59 PM
