Xenon Headlight. Audi A6. 3.2 fsi
#11
xenon with led 09 mod to 05.mod
Is the LWR module, the normally problem ? What words in text under is correct for the LWR
-If your Audi A6 S6 RS6 C5 xenon headlight have problems, like light failed, dipped beam not working, flickering or have any other issues, you only need to change or replacement related original xenon parts like: ballast, gas discharge bulb, igniter or wire harness, cable to repair your HID light is ok, no need to cost a lot of money to buy a whole brand new headlight assembly like the car dealer suggest.
Normally speaking, when your headlight have problem, check out the fuse first, if it’s ok, then replace the factory fit xenon control unit box ballast is ok, because from our many years experience, when the headlight not work, 90% of the problem is on the ballast.
.And questions twice, can the xenon led lamps for 09 mod pass into the 06 model ? Just plug and play?
#12
Ballast or range motor?
Hey, i have buy the LWR modul now,
But when I read here,it's 90% the ballast so is the reason the light head range control doesn't work?
If I must guess" all parts is maybe better to buy completely. 😄.
Link
http://www.oemxenonshop.com/Audi-A6-RS6-S6-OEM-Headlight-OEM-HID-Ballast-Bulb-Igniter-Replace.html
Link
#13
Electronic in this car with ripple, a reality. Switches on some components so often accompanies other related errors up. Replacing xenon, afterwards one fog light goes on and off. Also the same problem came with the headlights range control. Audi change the bulbs, and say I didn't need to change the regular..( because it works 10% of the time. But im not sure what so is the error reasons for range control. *Maybe ballast is problem, will the errors code came directly to the fault component? *
I've got a 99 A6 Avant with halogen projector headlights. Xenons were an option for this model/year.
Jenner
01-20-2004 01:09 PM
