2013 A7 wont power down
#11
Z
#12
In some U.S. MY2013 and 2014 models, Audi enabled the coding for this "feature" that would shut the engine off when opening the driver door (at some point later they disabled it, most likely due to owner complaints). My 2013 A6 came from the factory with it enabled. There is a way to disable this with a VCDS Vag-Com. Here is the coding (I can't vouch for it's accuracy as my dealer did mine for me).
Module 46
Long coding last byte is 0F; change it to 00
Press "Do It" (or "Save")
The engine should now continue to run when the driver door is opened.
Module 46
#13
The headlights will turn off after about 20 seconds but the LED lights stay on for like 20min... this only happens at night when the headlights were on.
#14
Module 46
Module 46
#15
In case you're not familiar with Ross-Tech's VCDS Vag-Com, it's a dedicated cable and software tool that links up to your car via the OBDII connector under the dash. It allows for changing many optional behaviors of different car systems as well as running a scan for faults when something isn't working properly. There are hundreds of AW threads on Vag-Com.
#16
Module 46
Module 46
Did this change... thanks a bunch for the info. My buddy came over with the Vag-Com and sure enough was able to turn that off for me. The dealership said they would have to flash my ECU and id lose my tune so had him do it.
#17
gideon-sf
Audi allroad
9
02-09-2010 11:51 AM
QuattroRings
01-18-2006 05:16 PM
S4MarkS4
10-31-2005 05:14 PM
