B&O stereo upgrade
B&O stereo upgrade
About to order an A7 - can anyone comment on the stereo upgrade - 1300W has got to go through some serious speakers - but my question is it worth it?
All feedback welcome.
Agree on the Bose being awful. Had that in our 2012 A7. For the 2015 A7 went with the B&O. Its night and day.
However, if your primary listening sources are FM/Sat radio and compressed media player audio I don't think I would spend the coin. To fully experience the B&O you need to have your own music lightly compressed on the Jukebox/SD or via CD/DVD-A
Audi Enthusiast
This is an important point. I bought my A7 with B&O and cancelled sat radio because B&O exposes the ridiculous compression and low quality. I haven't heard the Bose, but I do really like the B&O, especially at medium to high volumes.
If I could go back in time. I would skip the BOSE upgrade, get the base speakers and replace them aftermarket. Replacing Bose speakers is harder because of the impedance.
If that sort of thing isn't you then B&O.
Sound is very subjective. One sound system can sound good to some ears but bad to others. I recommend that you audition both sound systems and decide whether you would like to shell out extra $$ for the B&O. If you do not appreciate the B&O over the Bose, don't spend the money.
I am an AV systems designer and I am particular with my personal sound system. I, however, an not so gung-ho as to spend thousands of dollars for an uber system, though. But, I will appreciate those kinds of systems if they sound good to me. That said, my S5 is equipped with a B&O system and I like the quality of the high-frequency range. It is much better than regular sound systems and almost comparable to my home set-up. The low-frequency (bass) response is lacking due to the small subwoofer driver. I wish it could have been a tad bit more substantial but I have learned to live with it. I am not big into heavy bass (gone are my days as a Dance DJ) anymore.
As for amplifier power (for the B&O in the A7), it is rated at 1,200 at 1% THD (Total Harmonic Distortion). This is over-rated to inflate the power output numbers. This is how boombox manufacturers advertise power output. Some even advertise power output based on 10% THD, which is absurd.
A truer sense of amplifier power output for more serious listening will be rated with a THD of around 0.1 to 0.01%. Most higher-end sound systems are even rated at 0.001% THD! At this THD rating, I estimate the B&O Amp's output to be around 800-watts.
I believe the B&O system in the newer A7 is a 15-channel system. This is based on info from the B&O website. 800-watts divided by 15 is only around 53 watts which is just about right for car speakers.
So, do not be fooled by the massive power output rating of the amp. It is combined power and you don't use all that power at once since music is a very dynamic signal. Most of the time, you'll only use around 1/3 of the rated amplifier or less power during normal use.
My Q5 has the same B&O as your S5. I find that the B&O is a little warmer and has a fuller mid bass that the Bose in my A7. The Bose is Bass and Treble heavy and not warm and smooth like the B&O. That's why I ordered it for my Q7.
