A/C odor
A/C odor
I am sure many of you have experienced this. When the A/C is on, there is no smell. When it's off, you smell mold. Where exactly should I spray the A/C cleaner into to get rid of the smell?
Mold grows where it's wet which means it probably down by the heater core. I would try removing the cabin filter and spray towards the box. You might want to replace the filter if it's not fresh.
Can you run the fan when spraying? That would suck the mist through the system but it might also spew it out the vents... Good luck.
The filter should be removed, and depending on the product that you use, you can spray into the vents, and into the air intake at the passenger footwell.
CarlDude69
05-29-2008 06:16 PM
chrisxmartin
06-21-2007 05:44 AM
STEALTH_6
05-06-2007 04:06 PM
JBM
08-12-2003 04:51 AM
