Heated Steering Wheel
The wheel will heat initially when the button on the wheel is pushed but does not maintain temperature. The temperature reverts to normal temperature in just a few minutes. Is this "normal" operation of the heated steering wheel?
The Owners Manual indicates the steering wheel will heat up and maintain the temperature until the button is pushed to turn it off... which is very different than my experience.
I love this feature but some people don't.
The temperature of the heated steering wheel is set to 28 degrees C, if you want to increase (or decrease it) is can be done by coding. Ask the dealer och do it your self if you have VCDS.
It's designed this way, and it sounds like yours is perfectly normal.
I also wish the steering wheel would stay warmer for a longer period of time, but it seems to lose heat shortly after it gets heated up.
I'm not a big fan of this design...one of the disappointing features I'd say.
Change the temperature of the heated steering wheel
This is a VAG com adjustment:
The factory preset temperature is 28 °C. If you want to increase or decrease it, go to module 16 (steering wheel), adaptation and select channel 10.
The preset value is 28 (which relates to 28 °C). Change this to the temperature of your choice and you are done. A temperature of 32 degrees has been tried and tested.
On my wife's 2009 Q7 I was not able to get into the module to make the change as it needed an access code which I could not find online. I do not believe there is a timer. Monitoring my 2012 A7 with the VAG COM it appears to turn on when the wheel temp sensor is greater than +/- 1 degree C from the set temp. At first the wheel is cold so it is on longer and more frequently. After the heater has been on for a while it runs less frequently and shorter time period but still maintains the +/- 1 degree pattern. I suspect it is because the wheel material inside has finally reached near the set temp. I set my wheel temp to 35C and it feels great especially given the winter the northeast US has been having.
Quetzal
Wheels & Tires Discussion
09-23-2015 07:50 PM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
mrprism133
09-07-2015 07:22 PM
carl viking
09-05-2015 05:31 AM
Curtisjh
09-04-2015 04:06 AM
