Pet peeves
#11
Which means the RADIO (on its own) can not be turned off. The MMI can be, but that wasn't the question (or the requirement).
#12
#13
So your solution, which was the first that came to my mind when I just discovered this issue has been tried but does not work!
#14
And that's where the rub is. It comes back at Volume 3, not at 0 as it was when it is turned off. The same way, it comes back at Volume 15 if you turn it off at any setting above 15. If you shut down at any volume between 3 and 15, it comes back at that level. We could not find any MMI settings to change this, not even in the hidden advanced menu or with VAG-COM.
#15
#17
That's strange - my 2014 A7 has the sound come back on at 2 when you start the car with it muted. And the highest it will start the volume at is 12. So I wonder if the differences are due to which audio system, MMI firmware revision, or some regional issue?
#18
Actually, I have the opposite problem. I have a 64 GB SD card in, and if the car has been off for more then 10 minutes, it takes a little over a minute before music will start playing from where it left off.
#19
While I am only guessing on this, it seems the SD card directory is cached and it takes 10 minutes or so for the cache to clear. As you have a large card with likely many entries in the directory, it takes a minute or so to read it all and write it into the cache.
#20
However, the original issue sure is a peeve.
