Subwoofer Box Build and Install
#42
#43
#44
I don't know of any installers there but I do know that getting the carbon components of the build is easy in the uk, just order from carbon mods or easy composites, they are both based in the UK I believe if you wish to build a box, its not very hard just time consuming I would be willing to answer any question you may have on the build process
#45
no more inset fitment, but I was also able to sand and paint/buff with an automotive gloss coat making it retardo shiny
Update* Ended up pulling the 1500 series sub out and replacing with a 2500 series DD audio 8 since the 1500 had a burr on the voice coil causing it to "clink" when moved just right and this required me to modify the box a little since the 2500 is much more "beefy" so it is now a flush mount sub but I think I like this better. I also had David and Eric with Tuning Gruppe in Mesa AZ do a GIAC flash on the car an man did that make the car feel and respond so much different.
#46
Even though this is not recent (I have wrapped the window and door handle trim in black) i figured i would through it up so some peeps can see what I've been doing with the exterior <br/>
#47
blackalak your car is badass!!
I have a question about the sub and any issues with Codes or powering down issues. I was seeking a similar setup, but i was told from the performance shop that they dont mess with it, and had no one they would recommend at that moment who could do a good job. Im in Dallas,TX for the record and it was Autoscope.
Thanks!
Also, im thinking for doing a similar GIAC tune and pulley. Just curious whats the fastest car you beat todate?
Thanks!
#48
Thanks!
Thanks!
#49
Awesome! I'm audio knowledge is very limited, so when you "piggyback" are you able to control the bass in terms of volume. And you kept the factory deck correct?
#50
yes, the bass is controlled via factory head unit, since the signal is coming from the factory unit as shown in post #16 on page 2 picture 2,
