Tire size for 21x10.5 wheel
Hey! Getting a set of 21x10.5 wheels for my A7 Pretige (20" sport package) and I keep getting mixed direction on optimal tire size. Can you Audi World gurus help a brother out?
Thanks!
Thanks!
it even will hit the fenders if you're lowered )))
even 285-30 PSS rubbing on slight drop.
On this pic is 285-30-21 with 25mm drop, it's not driveable, only for photo. Even with slight drop of 10mm it rubs on a sharp turns and speedbups.
The only setup for 21x10,5 ET27 and drop is a stretched tire, 275-30 will be perfect.
My setup is 21x10,5 ET27/275-30-21 Conti Sport 5P
It's a little bit tight but doable.
https://pp.vk.me/c630518/v630518623/...e9Sr5i_iyM.jpg
Also i can add that you shoud measure wideness of the desired tire because it's very vary for each manufacturer. P-Zero wider than PSS, PSS is wider than Conti for example. If you're not sure about will it fit or no, just mount 1 tire, it should be stretched.
09S5 (08-22-2022)
I got a set of AG M510 21x10.5 et27, I'm not lowered and I'm wanting to go with 285/30/21 because of the bigger sidewall, but if need be I'd like to do a mild drop if the look isn't what I want.
been stuck on a tire and wheel package....alot of mixed info on the internet..my stock 20's tuck nicely on a 275/35zr20 w/ the H&R lowering springs... want to step up to a 21x10/10.5 and not have drivability issues
Karrera4
11
09-17-2018 11:43 AM
