Why Isn't M Mode on Heads Up Display
Old 05-05-2012, 08:52 AM
  #11
jfourman's Avatar
Default No luck on gear display
Originally Posted by Stevial
yep vag com, its in the instrument cluster in adaptations, you should be able to find it
Stevial: I found "Upshift display in center panel" and made it "active". ...no luck. I went back in to confirm that it was "active". Display while driving is still just "D".
If you are in VAG Com anytime soon, could you have a look at what you may have made active to get the gear to display. None of the other options seem relevant. Thanks.
Old 05-05-2012, 09:20 AM
  #12
jfourman's Avatar
Stevial: I found it. It is in "02 Auto Trans", "10-Adaptations". Set "Single gear display" to "D=On/S=On".
Thanks.
Old 05-05-2012, 06:10 PM
  #13
Stevial's Avatar
Thanks.
sweet
Old 05-06-2012, 03:08 PM
  #14
BlueSander's Avatar
Originally Posted by Knuck
Yes but when your driving aggressively on curvy mountain roads with no shoulders and 200 foot drops, you don't want to have to take your eyes off the road which you have to do to look at the Instrument Cluster display.
If you'd like to drive like that and you need to know what gear you are in, I highly suggest you against doing it. It would be a nice touch to have it on the headup display but otherwise, it's useless.
Old 05-06-2012, 10:02 PM
  #15
Knuck's Avatar
It is more than a nice thing to have. If you drive with music on, at least for my ears, it is very difficult to hear the engine. If you drive at high RPM all the time then I agree you can feel where you are at in the range, however, if you are on roads that go from extremely tight and twisty to straight, I prefer not to have be at 4000 plus RPM for the entire time. If you get down below 2500 RPM it is very difficult to feel or hear which gear you are in as this is an 8 speed transmission with very little feel at lower RPM between gears 5 through 8.
I am not sure how much experience you have on these type of roads or if you have much experience with standard vehicles, but to know exactly which gear you are in at any given time is extremely useful. For example, if you are travelling at 140 kms/hr along a straight and come upon a turn recommended at 40 kms/hr it is extremely important to know if you are in 8th or 5th as there is very little time to downshift into the appropriate gear to safely handle the corner.
cooltsi
10-23-2017 03:14 PM
triston1211
05-06-2013 11:14 AM
scotskier
Q7 MK 1 Discussion
03-22-2012 12:45 PM
BillA3A4
TT (Mk2) Discussion
11
03-04-2010 08:22 AM
Atlanta1996
A4 (B7 Platform) Discussion
11
07-10-2006 05:03 PM
Quick Reply: Why Isn't M Mode on Heads Up Display
