1998 A8 4.2L MAP Sensor location?
I'm a new A8 4.2 owner.
I got a code: Manifold absolute pressure or Bar pressure low input.
Would someone please tell me where the MAP sensor is located?
There is no MAP sensor. The V8 engine uses an airflow meter and throttle position sensor.
I would suggest scanning it with VCDS from Ross Tech which will give you much more accurate codes than a generic OBDII scanner.
pelletman
05-19-2018 04:47 PM
Jack27t
02-28-2012 06:19 AM
eventuallyblue
12-18-2004 03:59 PM
