2002 A8L D2 Limp mode and intermittent slipping in 2
Started thudding as it went down the lower gears, eventually went into limp mode after revving in second.
It does this intermittently, but tolerable driving if I catch the gas before it revs too high. Highway cruising no problem.
Fault codes
17116 Gear 2 P0732 35-10 Incorrect Ratio Intermittent
17114 Gear Ratio Monitoring P0730 35-00 Incorrect Gear Ratio
18032 MIL Request signal active (Check for TCM Errors too!)
The transmission fluid is at the correct level but due for a filter change.
Can anyone diagnose this to being just a control or sensor or am I really in for a reconditioned transmission?
I have just clocked 292,000 miles.
Chris
Fault codes
Chris
Pretty sure that trans is going to need to come apart. If you just get P0730 intermittent and no gear errors, it can be a sensor. But if that code comes with a gear fault as well there are internal problems.
Seems like a need a rebuilt transmission then. I still drive it carefully 500 miles a week using manual mode which is actually fun.
What would you recommend as the best inexpensive repair method?. Both my local Audi/VW mechanics have declined this "big job".
I am in Orange County NY.
Thanks 123quattro.
Good evening everyone im new to this site . can anyone help me out. I've bin having a little problem with my 2009 audi A8 4.2 L , my car has bin going into limp mode not all the time just every 2 to 3 months. but now its real bad its become and everyday thing... I just scan the car with my VCDS
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 6C
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Not registered 0011
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine ( ) Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 J HW: 4E1 907 560
Component: 4.2l V8/4V 0010
Revision: 71H22--- Serial number: AUX3Z0H5752422
Coding: 01060009190F0120
Shop #: WSC 02313 785 00200
VCID: 295986D8806F6E07EE-807C
2 Faults Found:
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 229033 km
Time Indication: 0
Date: 2019.07.27
Time: 21:40:02
Freeze Frame:
RPM: 667 /min
Load: 36.1 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 49.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
001169 - Secondary Air Injection System: Bank 1
P0491 - 002 - Insufficient Flow
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 229035 km
Time Indication: 0
Date: 2019.07.28
Time: 06:21:06
Freeze Frame:
RPM: 1131 /min
Load: 53.3 %
Speed: 0.0 km/h
Temperature: 38.0°C
Temperature: 33.0°C
Voltage: 13.335 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4461860
Coding: 0000002
VCID: 234594F0E243B457A4-8076
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0007597
Shop #: WSC 12345 000 00000
VCID: 2A5B79D48569651FE7-807E
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H5752422
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFF31CEB85278F81-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 2040
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 244797ECE74DB36FDD-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348FQ087530145
Coding: 0000003
Shop #: WSC 59320 002 1048576
VCID: 336564B052A324D754-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000067733
Subsystem 3 - Serial number: 0111.06.080000000100010064˙
Subsystem 4 - Serial number: 010064˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000151340
Coding: 0102737
VCID: 1C37AF0CDF3D8BAF65-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO18062008065A000000000225˙89
Subsystem 5 - Serial number: 000225˙898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO19062008065A00000000
Subsystem 7 - Serial number: 65A000000000037˙
5 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 42
Reset counter: 156
Mileage: 226775 km
Time Indication: 0
Date: 2019.06.24
Time: 03:58:23
Freeze Frame:
Voltage: 12.40 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 156
Mileage: 226775 km
Time Indication: 0
Date: 2019.06.24
Time: 03:58:23
Freeze Frame:
Voltage: 12.40 V
00003 - Control Module
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 16
Reset counter: 156
Mileage: 227017 km
Time Indication: 0
Date: 2019.06.29
Time: 04:39:30
Freeze Frame:
Temperature: 48.0°C
01592 - Air Quality Sensor (G238)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 2
Reset counter: 176
Mileage: 227781 km
Time Indication: 0
Date: 2019.07.12
Time: 21:55:08
Freeze Frame:
Temperature: 25.0°C
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 228574 km
Time Indication: 0
Date: 2019.07.21
Time: 23:31:52
Freeze Frame:
Temperature: 43.0°C
Speed: 0.0 km/h
(no units): 193.0
(no units): 71.0
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143123
VCID: 387F539C4BC5C78F61-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 168
Mileage: 228052 km
Time Indication: 0
Date: 2019.07.15
Time: 02:37:36
01494 - Bulb for Parking Lamps; Left (M1)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 229035 km
Time Indication: 0
Date: 2019.07.28
Time: 06:20:29
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 168
Mileage: 0 km
Time Indication: 0
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 227526 km
Time Indication: 0
Date: 2019.07.07
Time: 02:51:19
01498 - Bulb for Parking Lamps; Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 229035 km
Time Indication: 0
Date: 2019.07.28
Time: 06:20:29
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
Shop #: WSC 02399 823 56573
VCID: 2B557CD04A937C171C-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0347347
Coding: 0000100
VCID: 31696EB8A8BF16C726-8064
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 134
Mileage: 228243 km
Time Indication: 0
Date: 2019.07.17
Time: 18:25:14
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV0003LVF
Coding: 0532707
Subsystem 1 - Part No: 4E0 910 339 C
Component: BF-Gewichtsens. H02 0040
Subsystem 2 - Serial number: 02YA3
Subsystem 3 - Serial number: 0001.01.0000H0200000000000˙63
Subsystem 4 - Serial number: 000000˙63328RB403D0FB73U˙63
Subsystem 5 - Serial number: 0FB73U˙63428RB403D104AFP˙63
Subsystem 6 - Serial number: 104AFP˙63528RB403D11574E˙63
Subsystem 7 - Serial number: 11574E˙63628RB403D10E41H˙63
Subsystem 8 - Serial number: 10E41H˙63729RB403D187DA ˙63
Subsystem 9 - Serial number: 187DA ˙63829RB403D17748R˙
Subsystem 10 - Serial number: 17748R˙
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H04000 Serial number: 90055080960023
Coding: 0012341
VCID: 26438DE49171417FC3-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 K HW: 4E0 920 951 K
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H5100091
Coding: 0000200
Shop #: WSC 60866 001 1048576
VCID: 2D5172C8B487722702-8078
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B086108244
Coding: F575DF7F706A0E00
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 228243 km
Time Indication: 0
Date: 2019.07.17
Time: 18:25:08
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8456413
Shop #: WSC 00000 000 00000
VCID: 1A3BA914D509F59F77-804E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000073060
Coding: 0000000
VCID: 61C9DEF8B8DFE647F6-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B557CD08A937C171C-807E
1 Fault Found:
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 229034 km
Time Indication: 0
Date: 2019.07.27
Time: 22:01:54
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
4 Faults Found:
01445 - Sensor for Driver Seat Fore/Aft (G227)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 226924 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
01893 - Belt Height Adjustment Position Sensor (G372)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 225420 km
Time Indication: 0
Date: 2019.06.01
Time: 22:44:43
01448 - Sensor for Driver Seat; Tilt Adjust (G232)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 225420 km
Time Indication: 0
Date: 2019.06.01
Time: 22:45:42
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 225420 km
Time Indication: 0
Date: 2019.06.01
Time: 22:55:32
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395F-087518471
Shop #: WSC 08185 444 92447
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000813500171
Coding: 0003477
VCID: 1D31A208C42782A792-8048
3 Faults Found:
02140 - Control Circuit for Left Front Makeup Mirror Light
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 142
Mileage: 228528 km
Time Indication: 0
Date: 2019.07.20
Time: 20:49:00
02141 - Control Circuit for Front Right Makeup Mirror Light
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 228572 km
Time Indication: 0
Date: 2019.07.21
Time: 23:01:00
02282 - Sunroof Drive; Obstruction Detection
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 184
Mileage: 228572 km
Time Indication: 0
Date: 2019.07.21
Time: 23:17:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0048686
VCID: 204F9BFCF355AF4FB9-8074
1 Fault Found:
01705 - Selection Switch for Mirror-Adjust (E48)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 228560 km
Time Indication: 0
Date: 2019.07.22
Time: 03:42:26
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040806110037
Coding: 0048686
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 156
Mileage: 224439 km
Time Indication: 0
Date: 2019.05.20
Time: 01:32:35
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000101416
Coding: 0000026
VCID: 2C577FCC8F9D7B2F15-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000026042
Coding: 0010111
VCID: 1E33A504C92199BF8B-804A
Subsystem 1 - Part No: 8K0 907 410 B
Component: HOMELINK H01 0010
Subsystem 2 - Serial number: 1770884T02SK01
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
Shop #: WSC 25447 002 1048576
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 69D9C6D840EFAE072E-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 228243 km
Time Indication: 0
Date: 2019.07.17
Time: 18:25:06
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352FZ087658526
Coding: 0000002
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 196
Mileage: 228052 km
Time Indication: 0
Date: 2019.07.15
Time: 02:32:29
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010765
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2806090442
Coding: 344530393135313035412056413032383036303930343432
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900057947
Coding: 0232125
Shop #: WSC 14131 113 07232
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000806090289
Shop #: WSC 12336 024 394758
VCID: 346767AC57AD23EF4D-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8510JX
Coding: 1120503
VCID: 5CB7EF0C9FBDCBAFA5-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 229033 km
Time Indication: 0
Date: 2019.07.27
Time: 21:40:02
Freeze Frame:
RPM: 667 /min
Load: 36.1 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 49.0°C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 229035 km
Time Indication: 0
Date: 2019.07.28
Time: 06:21:06
Freeze Frame:
RPM: 1131 /min
Load: 53.3 %
Speed: 0.0 km/h
Temperature: 38.0°C
Temperature: 33.0°C
Voltage: 13.335 V
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV 2040
Coding: 4071648
Coding: 0000003
Coding: 0102737
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 42
Reset counter: 156
Mileage: 226775 km
Time Indication: 0
Date: 2019.06.24
Time: 03:58:23
Freeze Frame:
Voltage: 12.40 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 156
Mileage: 226775 km
Time Indication: 0
Date: 2019.06.24
Time: 03:58:23
Freeze Frame:
Voltage: 12.40 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 156
Mileage: 227017 km
Time Indication: 0
Date: 2019.06.29
Time: 04:39:30
Freeze Frame:
Temperature: 48.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 176
Mileage: 227781 km
Time Indication: 0
Date: 2019.07.12
Time: 21:55:08
Freeze Frame:
Temperature: 25.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 183
Mileage: 228574 km
Time Indication: 0
Date: 2019.07.21
Time: 23:31:52
Freeze Frame:
Temperature: 43.0°C
Speed: 0.0 km/h
(no units): 193.0
(no units): 71.0
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 168
Mileage: 228052 km
Time Indication: 0
Date: 2019.07.15
Time: 02:37:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 229035 km
Time Indication: 0
Date: 2019.07.28
Time: 06:20:29
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 168
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 227526 km
Time Indication: 0
Date: 2019.07.07
Time: 02:51:19
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 229035 km
Time Indication: 0
Date: 2019.07.28
Time: 06:20:29
Revision: 00000000
Coding: 020000
Coding: 0000100
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 134
Mileage: 228243 km
Time Indication: 0
Date: 2019.07.17
Time: 18:25:14
Coding: 0532707
Coding: 0012341
Coding: 0000200
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 228243 km
Time Indication: 0
Date: 2019.07.17
Time: 18:25:08
Coding: 0000000
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 229034 km
Time Indication: 0
Date: 2019.07.27
Time: 22:01:54
Coding: 4071658
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 226924 km
Time Indication: 0
Date: 2008.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 225420 km
Time Indication: 0
Date: 2019.06.01
Time: 22:44:43
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 225420 km
Time Indication: 0
Date: 2019.06.01
Time: 22:45:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 225420 km
Time Indication: 0
Date: 2019.06.01
Time: 22:55:32
Coding: 0003477
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 142
Mileage: 228528 km
Time Indication: 0
Date: 2019.07.20
Time: 20:49:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 228572 km
Time Indication: 0
Date: 2019.07.21
Time: 23:01:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 184
Mileage: 228572 km
Time Indication: 0
Date: 2019.07.21
Time: 23:17:00
Coding: 0048686
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 228560 km
Time Indication: 0
Date: 2019.07.22
Time: 03:42:26
Coding: 0048686
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 156
Mileage: 224439 km
Time Indication: 0
Date: 2019.05.20
Time: 01:32:35
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000922
Coding: 0000018
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 134
Mileage: 228243 km
Time Indication: 0
Date: 2019.07.17
Time: 18:25:06
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 196
Mileage: 228052 km
Time Indication: 0
Date: 2019.07.15
Time: 02:32:29
Coding: 0032364
Coding: 0232125
Coding: 1120503
Coding: 0032364
Joona Lauri Kudjoi
03-02-2017 09:29 AM
planbs4
02-22-2010 07:48 PM
pdacosta
16
05-16-2006 03:56 PM
