Sponsored by:
Sponsored by:
4.2 engine failure after timing belt change
Old 05-22-2015, 04:55 AM
  #21
silverd2's Avatar
Originally Posted by BrianC72gt
Turning the engine backwards yields nothing reliable...
A huge DITTO to that!
Why would you turn the engine backwards?
What tutorial did you use? ...Certainly not Bentley (recommended)(?)
A warning you'll find repeated in Bentley, especially in the timing belt procedure >>
Old 06-16-2015, 04:56 AM
  #22
richard-tx's Avatar
Originally Posted by jfrahm
Scoring? B.S. How do you score a cylinder with a bent valve? This can happen if a valve is broken and bouncing around in the cylinder but usually all that happens is you get some marks on the piston crown and a valve or valves that will not close.
The way that can happen is if the valve tags the piston in the ring land area. It bends the outer edge of the piston down and the top compression ring is now stuck in it's groove. Trying to run or start the engine with a stuck ring results in scoring of the cylinder wall. I have seen it happen.
Old 06-17-2015, 12:19 PM
  #23
Kitrods's Avatar
Originally Posted by Kitrods
Well I think I have the same issue. Except I did the belt myself used the tool to lock in timing. Rotated it 2 times to be sure no clearance issues. After I started it sounded fine for 5 min then some noises I never hear started. A moaning sound like one of the pulleys was bad. Then I hear a loud click and the engine stops. I rotated the engine backwards and see the timing is dead on. Opened the valve cover on the driver side and the chain has lots of slack. I guess pulling the head is next?
Rotating it backwards was only a very small amount and at that point it was toast anyway. No cyl scoring as not enough run time with damage. But 1 valve was broken off in 3 parts in cyl 2 and 3 other intake valves bent on same side
Old 06-17-2015, 12:20 PM
  #24
Kitrods's Avatar
Turns out it was a failed tensioner and pad
mattyg916
01-05-2015 08:06 AM
RobCT
4.2 V8 Discussion
10
04-15-2012 10:53 AM
galkokolaf
08-20-2010 01:43 AM
pntbllfun
04-25-2010 05:57 PM
nynyvtecjstkickdinyo
NY / NJ / CT Discussion
04-21-2008 05:09 PM
Quick Reply: 4.2 engine failure after timing belt change
