ABS error light - 00301 Return Flow Pump Implausible signal
#21
Hey! I had the same problem with ABS unit on my A8, first I bought another unit, but the error was still there, than I bought another unit, the error was still there!!! so I found a very good car electrician, and after two hours he fixed the error, he changed some cables, I dont know exactly which, but I recommend you find a good electrician...
Good luck
Good luck
#22
I have a similar issue with s8 2001 with ESP, where once I had problem with ABS module or pump that was stuck on with some kind of electric failure. After coming from work i encountered an empty battery. My bro checked for problems and knocked on the relay and after that it was working fine for a month or two. Later the light came on and now its disappearing when i start my drive but when i brake or drive a few meters it just comes on again - when it comes on i can hear the relay clicks under foot well. I also have a small leak on top of the ABS module, where the brake lines connect. Now I have changed both relays under LHD drivers wheel, checked the fuse in the trunk and have not figured out the issue yet.
#23
Whirly
01-16-2004 07:16 PM
